Home » Language IDEs » Java Development Tools (JDT) » Javac cannot infer type from lambda body but ECJ does
Javac cannot infer type from lambda body but ECJ does [message #1754309] Thu, 16 February 2017 04:54 Go to next message
I ran into a problem where Java code using generics with lambda functions compiles in Eclipse but not with ECJ. The following code compiles fine with ECJ:
import java.util.function.Function;
public class Playbook {
    static class A {
    static class B {
    static class Property<T> {
    static class Var<T> {
        static <T, U> Var<U> mapBidirectional(final Property<T> src, final Function<? super T, ? extends U> f, final Function<? super U, ? extends T> g) {
            return null;
        void bindBidirectional(final Property<T> other) {
    private static A f(final B x) {
        return null;
    private static B g(final A x) {
        return null;
    public void bindTimeString1(final Property<A> timepoint, final Property<B> textProperty) {
        Var.mapBidirectional(textProperty, s -> new A(), t -> new B()).bindBidirectional(timepoint);
    public void bindTimeString2(final Property<A> timepoint, final Property<B> textProperty) {
        Var.mapBidirectional(textProperty, Playbook::f, Playbook::g).bindBidirectional(timepoint);
    void f(final Property<Integer> p) {
But javac rejects it with an error:
[ERROR]Playbook.java:[35,90] incompatible types: main.java.Playbook.Property<main.java.Playbook.A> cannot be converted to main.java.Playbook.Property<java.lang.Object>
From reading on Stackoverflow, it could be a limitation/bug in javac, but I am not sure since other answers indicate that this is mandated by the JLS. IMHO this code should compile with javac since the types can be inferred correctly, as proven by ECJ.
Re: Javac cannot infer type from lambda body but ECJ does [message #1754354 is a reply to message #1754309] Thu, 16 February 2017 12:00 Go to previous messageGo to next message
Welcome to Java 8 type checking Smile
Lot's of corner cases exist, where the three entities, JLS, javac and ecj have four different opinions Smile
Luckily, for your example I can confirm that Oracle seems to have fixed a bug to the result that your example will be accepted in Java 9 (tried with build 9-ea+152).
Re: Javac cannot infer type from lambda body but ECJ does [message #1754426 is a reply to message #1754354] Fri, 17 February 2017 11:25 Go to previous messageGo to next message
Thanks for testing this.
It's amazing how many bugs are found in the type inference of Java 8. On top of that there is at one issue in the type system itself which allows you to compile unsound code without casts which generates a type-error at runtime. Example code and the paper can be found at http://io.livecode.ch/learn/namin/unsound.
Re: Javac cannot infer type from lambda body but ECJ does [message #1754458 is a reply to message #1754426] Fri, 17 February 2017 19:07 Go to previous message
Type inference in a language like Java is inherently complex. The authors of JLS did a tremendous job, still not good enough to ensure that different compilers *always* come to the same result. We're still working on this Smile
Regarding the paper by Amin & Tate: I like to disagree with one of their examples. See https://bugs.eclipse.org/510900 for analysis why JLS 8, ecj and javac 9 all reject the unsound program as expected.
Previous Topic:Error message: Target runtime jdk1.8.0.121 is not defined
Next Topic:JRE library unapears
Current Time: Sat Jul 19 17:27:48 EDT 2025
Powered by FUDForum. Page generated in 0.03785 seconds
