Home » Modeling » VIATRA » vaitra queries visualised using Sirius(vaitra queries visualised using Sirius)
vaitra queries visualised using Sirius [message #1753567] Tue, 07 February 2017 12:51 Go to next message
I was wondering if an early version of this feature described at siriusCon 2016 made it into the 1.5 release of Viatra?
Neil
Re: vaitra queries visualised using Sirius [message #1753568 is a reply to message #1753567] Tue, 07 February 2017 12:57 Go to previous messageGo to next message
Hi Neil,
sadly, the graphical editor for pattern definitions was not stable enough to include it in VIATRA. We have identified a few key areas that need to be worked on, mostly from the stability standpoint, but so far we did not have enough time to fix it. It is still in our to do list, but have no estimated time of inclusion.
Zoltán
Re: vaitra queries visualised using Sirius [message #1753581 is a reply to message #1753568] Tue, 07 February 2017 16:16 Go to previous messageGo to next message
Thanks Zoltan,
I have a DSL similar to xcore ( which may or may not use vql) and I am looking at making some visual representation of it in eclipse Che. So I may try to make xcore work well in Che as a GitHub project and try to have some visual representation of xcore in Che. This will mean I need to look at some of the same issues of synchronisation that you will have looked at in Sirius representations of viatra query language using xtext , and we're explained well in the siriuscon talk..Che of course uses a very different API from Sirius and RCP., but some of the lessons learnt will be useful for me. I will take a look at your Sirius work when it is ready, and if you ever look at Che integration ( e.g. For Mondo) perhaps some of my work will be useful for you too.
Thanks, Neil
Re: vaitra queries visualised using Sirius [message #1753623 is a reply to message #1753581] Wed, 08 February 2017 04:04 Go to previous messageGo to next message
Hi Neil,
I can share the source code of our current state with you (see Gerrit change https://git.eclipse.org/r/78055), but we are planning big changes because the following aspects:
* The fact that Xbase-using languages (such as Xcore, Xtend or VQL) changes in the textual syntax results in (a) rebuilding the EMF-based AST, and (b) rebuilding an inferred model structure used for code generation. This use case has some low-level technical issues (some of them are already solved in current Sirius/Xtext versions, but in general the situation is not perfect).
* In case of VQL, there is a large semantic gap between the EMF-based AST and the graphical representation, making model modification operations more complex.
For these reasons, we are planning to go with two separate syntaxes instead, and will not provide automated bidirectional synchronization between the two representation. The concrete details are being finalized, but we will have either an automated unidirectional transformation from the graphical to the textual syntax, and provide some on-demand transformation for the other direction, or we will have only on-demand synchronization between the languages.
I hope this was clear; if you have any more question, feel free to ask.
Zoltán
Re: vaitra queries visualised using Sirius [message #1753634 is a reply to message #1753623] Wed, 08 February 2017 05:37 Go to previous message
Thanks Zoltan,
that is clear and very useful.
Hopefully I will not have a large semantic gap between the EMF-based AST and the graphical representation for my DSL, but I will not know until I have done further investigation.
Neil
Previous Topic:queries on queries in VIATRA
Next Topic:Use qualified Classifier name
Current Time: Sat Jul 19 10:51:04 EDT 2025
Powered by FUDForum. Page generated in 0.08015 seconds
