Home » Language IDEs » C / C++ IDE (CDT) » Code index doesn't work(F3 failed)
icon5.gif  Code index doesn't work [message #1753410] Mon, 06 February 2017 02:24 Go to next message
In my project when I press F3 on some code symbol, I got the following:
Could not find "Symbol" in index
I executed "Create parser log file" and found a lot of errors like:
Unresolved inclusion: stdint.h in file sourcecontrol://jazz/default...
Scanner problems:
Unresolved inclusion: <path/to/file.h> in file: D:\path\to\file.cpp:18
Unresolved names:
Attempt to use symbol failed: SYMin file D:\path\to\file.cpp:38
Is any way to fix it?
Re: Code index doesn't work [message #1753580 is a reply to message #1753410] Tue, 07 February 2017 16:05 Go to previous message
You need to inform the Indexer about the non-standard include directories with User Settingss on the Entries tab at
Project --> Properties --> C/C++ General --> Preprocessor Include Paths, Macros etc.
http://help.eclipse.org/neon/index.jsp?topic=%2Forg.eclipse.cdt.doc.user%2Freference%2Fcdt_u_prop_general_sd_entries.htm
The compiler builtins also may not have been obtained.
Go to the Providers tab and make sure they are enabled.
[Updated on: Tue, 07 February 2017 16:43] by Moderator
Previous Topic:adapting a C++ project to Eclipse
Next Topic:Recipe for target error when printf added in Mars
Current Time: Sun Jul 20 08:28:04 EDT 2025
Powered by FUDForum. Page generated in 0.03069 seconds
