Home » Modeling » TMF (Xtext) » Cross Reference handling in Inferrer(Looking for right code for generating Java code from cross reference)
Cross Reference handling in Inferrer [message #1753339] Sat, 04 February 2017 01:27 Go to next message
Hello again,
I have created a sample dsl for my question. I created two types of Property, one using cross-reference and the other using JvmTypeReference.
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.xbase.Xbase
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
	objects += Object*;
Object:
	EntityObject | StringObject;
EntityObject:
	'entity' name=ValidID '{'
		properties += Property*
Property:
	PropertyTypeA | PropertyTypeB;
PropertyTypeA:
	'property_a' name=ValidID ':' type=[Object|ValidID];
PropertyTypeB:
	'property_b' name=ValidID ':' type=JvmTypeReference;
StringObject:
	'string' name=ValidID body=XBlockExpression;
In the standard Domainmodel example, most of the types are specified as JvmTypeReference. IJvmModelInferrer may be simple or standard. However, when it comes to content-assist in the generated editor, it provides too many choices (see TypeB attached).
We would rather prefer to use TypeA Property so that we can get better content-assist in the generated editor (see TypeA, attached). However, I was not successful to make this work with IJvmModelInferrer.
Code for mapping EntityObject follows.
	def dispatch void infer(EntityObject element, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
 		acceptor.accept(element.toClass(element.name)) [
 			for (property : element.properties) {
 				if (property instanceof PropertyTypeB)
	 				members += property.toField(property.name, property.type)
	 			else
	 				members += property.toField(property.name, /* what code should come here? */)
I tried to find a discussion similar to mine and found the following (I am not looking for ProposalProvider route).
[url= https://www.eclipse.org/forums/index.php/t/268675/]
It seems no resolution was made at that time. I tried several approaches but did not work as expected. I would appreciate any advice on this.
Akira
Re: Cross Reference handling in Inferrer [message #1753341 is a reply to message #1753339] Sat, 04 February 2017 01:54 Go to previous messageGo to next message
Sorry I forgot to include images.
  • Attachment: typeA.png
    (Size: 26.96KB, Downloaded 128 times)
  • Attachment: typeB.png
    (Size: 83.36KB, Downloaded 113 times)
Re: Cross Reference handling in Inferrer [message #1753342 is a reply to message #1753341] Sat, 04 February 2017 02:06 Go to previous messageGo to next message
Can you follow the cross ref and get the property object ?
If yes
val String name = ... // name of ref.type
// could result in x.y.Z
name.typeRef
[Updated on: Sat, 04 February 2017 02:28] by Moderator
Re: Cross Reference handling in Inferrer [message #1753343 is a reply to message #1753342] Sat, 04 February 2017 03:59 Go to previous messageGo to next message
e.g.
	 			else if (property instanceof PropertyTypeA){
	 				val String name = property.type?.name
	 				if (name !== null) {
	 					members += property.toField(property.name, name.typeRef)
Re: Cross Reference handling in Inferrer [message #1753369 is a reply to message #1753343] Sat, 04 February 2017 19:08 Go to previous message
This works. Thank you very much!
Previous Topic:Xtext, eclipse Che and outline view
Next Topic:Type Resolution within XBlockExpression
Current Time: Sat Jul 19 13:42:05 EDT 2025
Powered by FUDForum. Page generated in 0.03810 seconds
