Home » Eclipse Projects » Eclipse Scout » Eclipse Scout Oxygen Releases
Eclipse Scout Oxygen Releases [message #1753304] Fri, 03 February 2017 10:42 Go to next message
This Forum topic is used to announce Scout Releases (Oxygen Version). Please use other topics in the scout forum to ask your questions. Questions and comments in this topic will be deleted.
With the Oxygen release train, we plan to release Scout 7.0.0 in June 2017.
We are following the Simultaneous Release Plan provided by the Eclipse fundation.
https://wiki.eclipse.org/Oxygen/Simultaneous_Release_Plan
This topic holds records of the different releases of this train (milestones, release candidate, ...)
[Updated on: Mon, 13 November 2017 05:32] by Moderator
Re: Eclipse Scout Oxygen Releases [message #1753305 is a reply to message #1753304] Fri, 03 February 2017 10:58 Go to previous messageGo to next message
Oxygen M5 released on 03.02.2017
Remember that this is only a preview release. APIs might change in the next milestone releases. Please consider our Neon release, if you are looking for our stable branch.
Eclipse IDE distribution (also called EPP): Eclipse for Scout Developers
Eclipse Runtime on maven central: Version 6.1.0.M5
Usage example in the parent POM of your scout application:
<dependency>
    <groupId>org.eclipse.scout.rt</groupId>
    <artifactId>org.eclipse.scout.rt</artifactId>
    <version>6.1.0.M5</version>
    <type>pom</type>
    <scope>import</scope>
</dependency>
See this artifact on mvnrepository.com: org.eclipse.scout.rt
Update site to install the Scout SDK in your Eclipse IDE (already installed in the Scout EPP):
http://download.eclipse.org/scout/releases/6.1/6.1.0/M5/
The demo applications using this version can be found on the features/version/6.1.0.M5 branch of our docs repository on GitHub.
[Updated on: Mon, 10 April 2017 11:47] by Moderator
Re: Eclipse Scout Oxygen Releases [message #1759326 is a reply to message #1753305] Mon, 10 April 2017 10:53 Go to previous messageGo to next message
Oxygen M6 released on 17.03.2017
Release Notes (6.1)
Eclipse Runtime on maven central: Version 6.1.0.M6
<dependency>
    <version>6.1.0.M6</version>
    <type>pom</type>
</dependency>
http://download.eclipse.org/scout/releases/6.1/6.1.0/M6/
The demo applications using this version can be found on the features/version/6.1.0.M6 branch of our docs repository on GitHub.
Next version on the Oxygen release train will be built from our 7.0.x Branch.
[Updated on: Tue, 30 May 2017 04:29] by Moderator
Re: Eclipse Scout Oxygen Releases [message #1764464 is a reply to message #1759326] Tue, 30 May 2017 04:33 Go to previous messageGo to next message
Oxygen M7 released on 19.05.2017
Have a look at the Release Notes (7.0)
Eclipse Runtime on maven central: Version 7.0.0.001_M7
<dependency>
    <version>7.0.0.001_M7</version>
    <type>pom</type>
</dependency>
http://download.eclipse.org/scout/releases/7.0/7.0.0/001_M7/
The demo applications using this version can be found on the features/version/7.0.0.001_M7 branch of our docs repository on GitHub.
[Updated on: Tue, 30 May 2017 06:31] by Moderator
Re: Eclipse Scout Oxygen Releases [message #1764469 is a reply to message #1764464] Tue, 30 May 2017 06:29 Go to previous messageGo to next message
Oxygen RC1 released on 26.05.2017
Eclipse Runtime on maven central: Version 7.0.0.005_RC1
<dependency>
    <version>7.0.0.005_RC1</version>
    <type>pom</type>
</dependency>
http://download.eclipse.org/scout/releases/7.0/7.0.0/005_RC1/
The demo applications using this version can be found on the features/version/7.0.0.005_RC1 branch of our docs repository on GitHub.
[Updated on: Thu, 08 June 2017 15:32] by Moderator
Re: Eclipse Scout Oxygen Releases [message #1765369 is a reply to message #1753304] Thu, 08 June 2017 15:39 Go to previous messageGo to next message
Oxygen RC2 released on 02.06.2017
Eclipse IDE distribution (also called EPP): Eclipse for Scout Developers (RC2)
Eclipse Runtime on maven central: Version 7.0.0.006_RC2
<dependency>
    <version>7.0.0.006_RC2</version>
    <type>pom</type>
</dependency>
http://download.eclipse.org/scout/releases/7.0/7.0.0/006_RC2/
The demo applications using this version can be found on the features/version/7.0.0.006_RC2 branch of our docs repository on GitHub.
Re: Eclipse Scout Oxygen Releases [message #1765465 is a reply to message #1765369] Fri, 09 June 2017 16:24 Go to previous message
Oxygen RC3 released on 09.06.2017
You will find all the informations about the latest release at the beginning of the Release Notes (7.0)
Previous Topic:Neon to Oxygen: Recommended approach
Next Topic:How to create a Dashboard in a TablePage
Current Time: Sat Jul 19 18:26:27 EDT 2025
Powered by FUDForum. Page generated in 0.04940 seconds
