Home » Language IDEs » C / C++ IDE (CDT) » Microsoft Visual C++ toolchain does not exist (Microsoft Visual C++ toolchain does not exist under Project \ Properties \ C/C++ Build \ Tool Chain Editor)
Microsoft Visual C++ toolchain does not exist [message #1752343] Sun, 22 January 2017 08:10 Go to next message
Problem Description:
index.php/fa/28182/0/Hello
My setup:
Windows 7
Eclipse Neon.2 / Eclipse Neon.1 (Same problem on both)
Microsoft Visual Studio Pro 2013
From Eclipse help I understand that this should work automatically
http://help.eclipse.org/neon/index.jsp?topic=%2Forg.eclipse.cdt.doc.user%2Fconcepts%2Fcdt_c_before_you_begin.htm
I also remember that in previous version, Microsoft Visual C++ used to appear on the list (even if not installed).
Does anyone run into the same problem and can help?
  • Attachment: eclipse2.png
    (Size: 85.60KB, Downloaded 14611 times)
Re: Microsoft Visual C++ toolchain does not exist [message #1752423 is a reply to message #1752343] Mon, 23 January 2017 11:14 Go to previous messageGo to next message
I assume you used the "Eclipse IDE for C/C++ Developers" package before. It doesn't include the "Visual C++" toolchain by default anymore. You have to install it as an optional feature. It's also not very maintained anymore.
Re: Microsoft Visual C++ toolchain does not exist [message #1752425 is a reply to message #1752423] Mon, 23 January 2017 11:26 Go to previous messageGo to next message
index.php/fa/28187/0/
  • Attachment: vcsupport.PNG
    (Size: 60.01KB, Downloaded 13956 times)
Re: Microsoft Visual C++ toolchain does not exist [message #1752527 is a reply to message #1752425] Tue, 24 January 2017 13:20 Go to previous messageGo to next message
Thanks, it does show me now the Visual C++ toolchain Smile
I tried to define the environment variables by running the "Visual Studio\VC\vcvarsall.bat" script using Developer Prompt for VS2013, which does defines the environment variables, but outside of the Prompt they still remain un-defined.
So I defined all of the environment variables manually (PATH, LIB, LIBPATH, INCLUDE) both on Windows and on Eclipse Project Properties \ C/C++ Build \ Environment
But still eclipse does not recognize the includes
If anyone happen to know a guide of how to set up eclipse with Visual C++ toolchain I would be grateful Smile
Re: Microsoft Visual C++ toolchain does not exist [message #1752851 is a reply to message #1752527] Sun, 29 January 2017 05:14 Go to previous message
Yaron Ba wrote on Tue, 24 January 2017 13:20
See if this helps: http://codewriterstips.blogspot.co.uk/2012/05/using-microsoft-c-compiler-with-eclipse.html
Visual Studio console sets up the environment for VS toolchain.
AFAIK, you won't be able to debug, only build and run.
Previous Topic:Selecting the correct Arduino tool chain
Next Topic:Compile errors with MinGW/CygWin/CDT
Current Time: Sun Jul 20 08:05:56 EDT 2025
Powered by FUDForum. Page generated in 0.06589 seconds
