Home » Eclipse Projects » Eclipse Platform » Eclipse Neon can't open twice without deleting metadata folder(Impossible to launch Eclipse Neon without deleting metadata folder first)
icon8.gif  Eclipse Neon can't open twice without deleting metadata folder [message #1750300] Mon, 19 December 2016 12:22 Go to next message
I have recently installed both Eclipse Neon and Eclipse Oxygen on Windows 7 SP1. In both installations I'm getting exactly the same problem that I never had before with Eclipse Mars. When I launched Eclipse Neon for the very first time, everything worked fine. However, whenever I quit Eclipse Neon and then try to restart it, Eclipse aborts and I get a message instructing me to look into the log file under the metadata directory located in the workspace. The only way out of this deadlock is to delete the entire metadata directory. Unfortunately, the same issue will keep reappearing at the following restart.
This is driving me crazy. Can anyone help? You will find the uploaded log file in the atttachments.
Best regards.
Charles
  • Attachment: .log
    (Size: 196.93KB, Downloaded 160 times)
Re: Eclipse Neon can't open twice without deleting metadata folder [message #1750345 is a reply to message #1750300] Tue, 20 December 2016 03:35 Go to previous messageGo to next message
The log suggests you've installed the JavaScript IDE and that SWT is running out of handles while starting the workbench. The log appears to have several sessions (starts of Eclipse) in it. I hate to suggest rebooting your machine, but does this happen even on a freshly rebooted machine where Eclipse is pretty much the only application that's creating windows? I.e., I think it's possible that so many applications have used up so many handles there are just not enough left for Eclipse.
Re: Eclipse Neon can't open twice without deleting metadata folder [message #1751325 is a reply to message #1750345] Sun, 08 January 2017 13:45 Go to previous messageGo to next message
Hi Ed,
The problem occurs even with freshly rebooted machine. I never had that problem with Eclipse Mars. I wonder if Neon is more resource consuming compared to Mars.
I wish you the best for 2017. Best regards
Charles
Re: Eclipse Neon can't open twice without deleting metadata folder [message #1751338 is a reply to message #1751325] Mon, 09 January 2017 01:36 Go to previous messageGo to next message
Very strange. If you start that Eclipse installation with a fresh new workspace, and the first thing you do once it opens is File -> Restart, does that also produce this result? Or perhaps this happens only when a specific editor or a specific view is open in the perspective?
Re: Eclipse Neon can't open twice without deleting metadata folder [message #1751671 is a reply to message #1751338] Thu, 12 January 2017 06:30 Go to previous message
I just tried that and I got the very same punishment. The .metadata/.log file is listed below:
!SESSION 2017-01-12 12:26:01.462 -----------------------------------------------
eclipse.buildId=4.6.1.M20160907-1200
java.version=1.8.0_111
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=fr_FR
Framework arguments: -product org.eclipse.epp.package.javascript.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.javascript.product
!ENTRY org.eclipse.equinox.event 4 0 2017-01-12 12:26:10.973
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/children/ADD] {ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.TrimBarImpl@1425e531 (elementId: org.eclipse.ui.trim.status, tags: [], contributorURI: null) (widget: Composite {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer@73385d3f, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (side: Bottom), org.eclipse.e4.data={ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.TrimBarImpl@1425e531 (elementId: org.eclipse.ui.trim.status, tags: [], contributorURI: null) (widget: Composite {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer@73385d3f, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (side: Bottom), AttName=children, EventType=ADD, Position=3, Widget=Composite {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolControlImpl@2361365c (elementId: org.eclipse.ui.ProgressBar, tags: [Draggable], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer@556aed22, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.StandardTrim, object: null)}, AttName=children, EventType=ADD, Position=3, Widget=Composite {}, NewValue=org.eclipse.e4.ui.model.application.ui.menu.impl.ToolControlImpl@2361365c (elementId: org.eclipse.ui.ProgressBar, tags: [Draggable], contributorURI: null) (widget: null, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer@556aed22, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.StandardTrim, object: null)} to handler org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler@6df31abf
!STACK 0
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:4559)
at org.eclipse.swt.SWT.error(SWT.java:4448)
at org.eclipse.swt.SWT.error(SWT.java:4419)
at org.eclipse.swt.widgets.Widget.error(Widget.java:482)
at org.eclipse.swt.widgets.TaskBar.createHandle(TaskBar.java:103)
at org.eclipse.swt.widgets.TaskBar.<init>(TaskBar.java:96)
at org.eclipse.swt.widgets.Display.getSystemTaskBar(Display.java:2597)
at org.eclipse.ui.internal.StandardTrim.createProgressBar(StandardTrim.java:72)
at org.eclipse.ui.internal.StandardTrim.createWidget(StandardTrim.java:49)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:308)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:186)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:108)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:51)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer.createWidget(ToolControlRenderer.java:108)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeChildrenHandler(PartRenderingEngine.java:296)
at sun.reflect.GeneratedMethodAccessor6.invoke(Unknown Source)
at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:80)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:294)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:303)
at org.eclipse.ui.internal.WorkbenchWindow.populateStandardTrim(WorkbenchWindow.java:1149)
at org.eclipse.ui.internal.WorkbenchWindow.populateBottomTrimContributions(WorkbenchWindow.java:1254)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:671)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:118)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:73)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1525)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1499)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:923)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:117)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEvent(WorkbenchSourceProvider.java:683)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1270)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1078)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1103)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1088)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1697)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2277)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4788)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:359)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1656)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2199)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5102)
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:231)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1270)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:805)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:669)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1059)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
!ENTRY org.eclipse.core.net 4 0 2017-01-12 12:26:14.655
!MESSAGE WinHttp.DetectAutoProxyConfigUrl for wpad failed with error 'L’URL d’auto configuration du Proxy n’a pas été trouvée' #12180.
!ENTRY org.eclipse.epp.logging.aeri.ide 2 16 2017-01-12 12:26:15.301
!MESSAGE Server 'org.eclipse.epp.logging.aeri.ide.server' failed with exception: Proxy Authentication Required. ; version: 2.0.3.v20160905-1331
!STACK 0
org.apache.http.client.HttpResponseException: Proxy Authentication Required
at org.eclipse.epp.internal.logging.aeri.ide.server.mars.HttpResponses$ProgressMonitorResponseHandler.handleResponse(HttpResponses.java:70)
at org.eclipse.epp.internal.logging.aeri.ide.server.mars.HttpResponses$ProgressMonitorResponseStringHandler.handleResponse(HttpResponses.java:92)
at org.eclipse.epp.internal.logging.aeri.ide.server.mars.HttpResponses$ProgressMonitorResponseStringHandler.handleResponse(HttpResponses.java:1)
at org.apache.http.client.fluent.Response.handleResponse(Response.java:90)
at org.eclipse.epp.internal.logging.aeri.ide.server.mars.HttpResponses.getContentWithProgress(HttpResponses.java:55)
at org.eclipse.epp.internal.logging.aeri.ide.server.mars.IO.refreshConfiguration(IO.java:69)
at org.eclipse.epp.internal.logging.aeri.ide.server.mars.ServerConnection.startUp(ServerConnection.java:103)
at com.google.common.util.concurrent.AbstractIdleService$2$1.run(AbstractIdleService.java:54)
at com.google.common.util.concurrent.Callables$3.run(Callables.java:93)
!SESSION 2017-01-12 12:26:44.221 -----------------------------------------------
Framework arguments: -product org.eclipse.epp.package.javascript.product -product org.eclipse.epp.package.javascript.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.javascript.product -data file:/D:/Profiles/chzerbib/neon-workspace/ -product org.eclipse.epp.package.javascript.product
!ENTRY org.eclipse.osgi 4 0 2017-01-12 12:26:52.238
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:70)
at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.processContents(TrimBarRenderer.java:134)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:665)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:536)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:520)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:747)
!ENTRY org.eclipse.osgi 4 0 2017-01-12 12:26:52.254
!STACK 0
!ENTRY org.eclipse.ui.workbench 4 0 2017-01-12 12:26:52.269
!MESSAGE Widget is disposed
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4533)
at org.eclipse.swt.widgets.Display.error(Display.java:1262)
at org.eclipse.swt.widgets.Display.checkDevice(Display.java:747)
at org.eclipse.swt.widgets.Display.getShells(Display.java:2248)
at org.eclipse.ui.internal.progress.ProgressManagerUtil.getModalShellExcluding(ProgressManagerUtil.java:321)
at org.eclipse.ui.internal.progress.ProgressManagerUtil.getDefaultParent(ProgressManagerUtil.java:376)
at org.eclipse.ui.internal.statushandlers.InternalDialog.<init>(InternalDialog.java:155)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialogManagerImpl.doAddStatusAdapter(WorkbenchStatusDialogManagerImpl.java:260)
at org.eclipse.ui.internal.statushandlers.WorkbenchStatusDialogManagerImpl.addStatusAdapter(WorkbenchStatusDialogManagerImpl.java:197)
at org.eclipse.ui.statushandlers.WorkbenchStatusDialogManager.addStatusAdapter(WorkbenchStatusDialogManager.java:158)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.showStatusAdapter(WorkbenchErrorHandler.java:95)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.access$0(WorkbenchErrorHandler.java:88)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler$1.run(WorkbenchErrorHandler.java:55)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4813)
at org.eclipse.ui.statushandlers.WorkbenchErrorHandler.handle(WorkbenchErrorHandler.java:52)
at org.eclipse.ui.internal.ide.IDEWorkbenchErrorHandler.handle(IDEWorkbenchErrorHandler.java:101)
at org.eclipse.ui.internal.WorkbenchErrorHandlerProxy.handle(WorkbenchErrorHandlerProxy.java:31)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:204)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:246)
at org.eclipse.ui.statushandlers.StatusManager$StatusManagerLogListener.logging(StatusManager.java:317)
at org.eclipse.core.internal.runtime.RuntimeLog.logToListeners(RuntimeLog.java:161)
at org.eclipse.core.internal.runtime.PlatformLogWriter.logged(PlatformLogWriter.java:103)
at org.eclipse.osgi.internal.log.ExtendedLogReaderServiceFactory.safeLogged(ExtendedLogReaderServiceFactory.java:88)
at org.eclipse.osgi.internal.log.ExtendedLogReaderServiceFactory.logPrivileged(ExtendedLogReaderServiceFactory.java:217)
at org.eclipse.osgi.internal.log.ExtendedLogReaderServiceFactory.log(ExtendedLogReaderServiceFactory.java:189)
at org.eclipse.osgi.internal.log.ExtendedLogServiceFactory.log(ExtendedLogServiceFactory.java:65)
at org.eclipse.osgi.internal.log.ExtendedLogServiceImpl.log(ExtendedLogServiceImpl.java:87)
at org.eclipse.osgi.internal.log.LoggerImpl.log(LoggerImpl.java:54)
at org.eclipse.osgi.internal.log.EquinoxLogFactory$1.log(EquinoxLogFactory.java:52)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:251)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-01-12 12:26:52.272
!MESSAGE
!STACK 0
at org.eclipse.ui.internal.WorkbenchWindow.updateLayoutDataForContents(WorkbenchWindow.java:2830)
at org.eclipse.ui.internal.WorkbenchWindow.setCoolBarVisible(WorkbenchWindow.java:2627)
at org.eclipse.ui.internal.ViewIntroAdapterPart.setBarVisibility(ViewIntroAdapterPart.java:243)
at org.eclipse.ui.internal.ViewIntroAdapterPart.dispose(ViewIntroAdapterPart.java:159)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.invalidate(CompatibilityPart.java:237)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.destroy(CompatibilityPart.java:403)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:161)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.doStop(Module.java:634)
at org.eclipse.osgi.container.Module.stop(Module.java:498)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-01-12 12:26:52.309
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.eclipse.swt.SWTException: Device is disposed
at org.eclipse.swt.widgets.Display.asyncExec(Display.java:710)
at org.eclipse.ui.internal.WorkbenchWindow$9.changed(WorkbenchWindow.java:726)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:114)
at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:343)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:178)
Previous Topic:Maven repository for platform bundles
Next Topic:AGAIN! After Eclipse update the setup won't start any more
Current Time: Sat Jul 19 14:45:32 EDT 2025
Powered by FUDForum. Page generated in 0.03465 seconds
