Home » Newcomers » Newcomers » Something buggy with Eclipse console ...(glitches in output)
icon9.gif  Something buggy with Eclipse console ... [message #1750882] Fri, 30 December 2016 20:29 Go to next message
For some reason, today in the middle of working on my project, Eclipse decided to stop outputting the first "print" statement, replacing it by a copy of whatever the following "print" was ...
the code is:
primes = open('C:/.../.txt','r').read()
primes = primes.split(',')
print("primes : ", primes)
sort = []
for i in range(10000): sort.append("".join(sorted(str(primes[i]))))
print("sort : ", sort)
the output now looks like:
index.php/fa/27989/0/
... Next, I added another "print" statement at the end, just to see what happens... The output is still doing something crazy ...
index.php/fa/27990/0/
I trying searching for whatever this problem might be, but couldn't find anything that was similar and/or I could understand (I'm pretty new at this game...)
Does anyone have any suggestions as to how one might go about fixing this madness? ... I tried installing a brand new Eclipse version, but the problem persists ...
  • Attachment: wtf1.jpg
    (Size: 23.31KB, Downloaded 406 times)
  • Attachment: wtf2.jpg
    (Size: 45.08KB, Downloaded 491 times)
Re: Something buggy with Eclipse console ... [message #1750902 is a reply to message #1750882] Sat, 31 December 2016 20:18 Go to previous messageGo to next message
Have you made sure that running your application outside of Eclipse gives you the results you intended?
Re: Something buggy with Eclipse console ... [message #1750903 is a reply to message #1750902] Sat, 31 December 2016 20:40 Go to previous message
I just got help with the problem. It turned out that decreasing the number of primes in the list made the code run fine, so i guess it's some kind of issue with memory. Confused
I was advised to use Anaconda and Spyder instead as it's supposedly less buggy.
Previous Topic:Gradle plugin error
Next Topic:can I store two configuration based on OS type for a project in eclipse
Current Time: Sun Jul 20 18:48:08 EDT 2025
Powered by FUDForum. Page generated in 0.10085 seconds
