Home » Modeling » Papyrus » menuContribution to papyrus model menu
menuContribution to papyrus model menu [message #1750695] Sun, 25 December 2016 12:28 Go to next message
i am working on a plugin, and by this plugin i want to extend papyrus plugin by adding command in popup menu when click on lifeline object in sequence diagram.
i have this menuContribution to add command to project explorer
<menuContribution
         locationURI=
         "popup:org.eclipse.ui.navigator.ProjectExplorer#PopupMenu?after=additions">
         <command
               commandId="SDPlugin.menus.myCommand"
               label="Run mycommand"
               tooltip="Do something with this project">
         </command>
      </menuContribution>
i want to add the same command to popup menu when i right click mouse button on lifeline item in the sequence diagram .
i tried to get the id of the menu using plugin Spy but i get Null, so how can i add the command to papyrus popup menu !
regards
Re: menuContribution to papyrus model menu [message #1750778 is a reply to message #1750695] Wed, 28 December 2016 10:55 Go to previous message
to add a popup menu item to Lifelines in the model explorer, you can use the following:
<extension point="org.eclipse.ui.menus">
  <menuContribution locationURI="popup:org.eclipse.papyrus.views.modelexplorer.modelexplorer.popup">
	 <command
		   commandId="<your-command-id>"
		   id="<your-contribution-id>"
		   label="Label"
		   style="push">
		<visibleWhen checkEnabled="false">
		   <iterate ifEmpty="false" operator="and">
			  <adapt type="org.eclipse.emf.ecore.EObject">
				 <instanceof  value="org.eclipse.uml2.uml.Lifeline"/>
			  </adapt>
		   </iterate>
		</visibleWhen>
	 </command>
  </menuContribution>
</extension>
Hope this helps!
Best wishes,
Philip
Philip Langer
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
[Updated on: Wed, 28 December 2016 10:56] by Moderator
Previous Topic:Thanks to all who made Papyrus my favourite modelling tool
Next Topic:Java Comments and Annotation with Code Generation
Current Time: Sun Jul 20 04:34:59 EDT 2025
Powered by FUDForum. Page generated in 0.03393 seconds
