Home » Eclipse Projects » Oomph » Not able to automate addition of ignored resources in eclipse
Not able to automate addition of ignored resources in eclipse [message #1750436] Wed, 21 December 2016 01:23 Go to next message
I need to automate addition of ignored resources in eclipse(windows->preference ->team->ignored resources).
I know the key for the preferences is /instance/org.eclipse.team.core/ignore_files.
But the problem is how to add multiple patterns like *.settings, *.project etc,
Re: Not able to automate addition of ignored resources in eclipse [message #1750453 is a reply to message #1750436] Wed, 21 December 2016 03:58 Go to previous messageGo to next message
Did you try just recording the changes you want?
<setup:PreferenceTask
    xmi:version="2.0"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
    key="/instance/org.eclipse.team.core/ignore_files"
    value="*.alsobogus&#xA;true&#xA;*.verybogus&#xA;true&#xA;"/>
Re: Not able to automate addition of ignored resources in eclipse [message #1750459 is a reply to message #1750453] Wed, 21 December 2016 04:22 Go to previous messageGo to next message
Yes I tried and it work well but the thing I want is, to avoid sharing one extra file "user.setup" (inside .eclipse directory) among others if I can do that using project.setup file. I defined all the preference in project.setup file, so just wanted to know if can define in that.
Thanks for your reply.
Re: Not able to automate addition of ignored resources in eclipse [message #1750462 is a reply to message #1750459] Wed, 21 December 2016 05:17 Go to previous message
Yes, you can put that task into the project.setup. In fact you can generally record changes into any *.setup file. Just open it in the editor and use the Record Preferences toolbar button to open the preferences dialog. Of course if you're using Git, it seems much more appropriate to put everything into your .gitignore files.
Previous Topic:Preference Task setting target platform status bar
Next Topic:Problems with the installed version
Current Time: Sat Jul 19 12:40:45 EDT 2025
Powered by FUDForum. Page generated in 0.04176 seconds
