Home » Modeling » Papyrus » Adapt shape appearance based on complex constraints
Adapt shape appearance based on complex constraints [message #1750155] Fri, 16 December 2016 09:08 Go to next message
I would like to change the color of a CallBehaviorAction in an ActivityDiagram depending on whether its called behavior (CallBehaviorAction.behavior) has a specific stereotype applied. For instance, all activites stereotyped as "SpecialActivity" are colored in red and, hence, a CallBehaviorAction calling a "SpecialActivity" should be colored in red as well.
I know that coloring can be handled by CSS but I suppose there is no CSS selector supported for such complex conditions (i.e., stereotype of a referenced element), is there? Otherwise, could anyone give me a hint what would be a good way how to achieve this programmatically?
Many thanks for your help,
Andreas
Re: Adapt shape appearance based on complex constraints [message #1751374 is a reply to message #1750155] Mon, 09 January 2017 08:42 Go to previous message
Hi Andreas,
I believe that it's indeed impossible with a papyrus css selector.
:Warning: , there is no clean-official way to achieve what you want, but here is one way
We managed to achieve a similar goal in SysML 1.4 by branching a custom css engine.
You may find the sources here and in the the afferent plugin.xml
https://git.eclipse.org/c/papyrus/org.eclipse.papyrus-sysml.git/tree/diagram/org.eclipse.papyrus.sysml14.diagram.common/src/org/eclipse/papyrus/sysml14/diagram/common/css/
The main goal is to add a rule in this file (sadly we had to extends many other files)
https://git.eclipse.org/c/papyrus/org.eclipse.papyrus-sysml.git/tree/diagram/org.eclipse.papyrus.sysml14.diagram.common/src/org/eclipse/papyrus/sysml14/diagram/common/css/dom/GMFSYSMLElementAdapter.java
For example deprecated
with
public static final String DEPRECATED = "deprecated"; //$NON-NLS-1$
     and the related code
we can call
[deprecated=true] {
	lineColor: orange;
in the css file.
Benoit
Previous Topic:Custom Palette for Sequence Diagram Editor
Next Topic:Programmatically get a list of registered profiles...
Current Time: Sun Jul 20 16:45:06 EDT 2025
Powered by FUDForum. Page generated in 0.03184 seconds
