Can't set Javadoc location for Eclipse libraries; Open External Javadoc (Shift+F2) doesn't work [message #174855] |
Tue, 24 August 2004 16:17  |
Originally posted by: mrtom.us.ibm.com
Using 2.1.3:
If I put the cursor on any Eclipse type (e.g. IFile), I get the error
message that the documentation location has not be configured.
So I open Project, Properties, Java Build Path, but I can't get anything
I set here to "stick". I edit the Javadoc location, navigate to the
right place, "Validate" tells me its okay, but when I close the Build
Path dialog and reopen it, the setting is blank again.
Any ideas? Shift+F2 works fine for Java standard and my own types.
Tom
Re: Can't set Javadoc location for Eclipse libraries; Open External Javadoc (Shift+F2) doesn't wor [message #174985 is a reply to message #174855] |
Wed, 25 August 2004 07:05  |
Originally posted by: daniel.megert.gmx.net
Tom Bridgman wrote:
> Using 2.1.3:
> anything I set here to "stick". I edit the Javadoc location, navigate
> to the right place, "Validate" tells me its okay, but when I close the
> Build Path dialog and reopen it, the setting is blank again.
Anything in .log?
Dani
> Tom
FUDForum. Page generated in 0.03713 seconds
