Home » Modeling » TMF (Xtext) » Problems with code generation
Problems with code generation [message #1749448] Tue, 06 December 2016 16:56 Go to next message
Hello guys.
I'm having a problem, I'm not getting information from the grammar tree in code generation. The situation is a bit unusual because my grammar is different.
What I need is to pass a valid entry in the grammar, such as:
The fridge SHALL detect and communicate information with AS MANY food packages AS POSSIBLE.
Capital letters are the operators of my grammar.
The output of this using the code generator should be:
SHALL (AS MANY AS POSSIBLE p)
p: The fridge detects and communicates information with food packages
However I am not able to use Xtend to generate this result.
My grammar was defined as:
//list of all requirements
Requirements:
	requirements+=Requirement+;
//each requirement is finalized with ";"
Requirement:
	(root+=General)+ ';';
//undefined types
terminal BOOLEAN returns ecore::EBoolean:'true'|'false';
terminal FREESTRING:  (('\\')?('a'..'z'|'A'..'Z'|'_'|'0'..'9'|','|'.'))*  ;
//Natural Language
NL hidden(WS): FREESTRING ( FREESTRING)*;
General:
	rest = Rest =>({UntilOperator.left=current}('UNTIL'|'until') right=General)*;
//aqui se encontram as demais regras da gramatica
Rest:
	Primitive|ShallOperator|MayOperator|EventuallyOperator|BeforeOperator|AfterOperator|InOperator|AsCloseOperator|AsOperator
Primitive:
	BooleanValue | StringValue
//primitives
BooleanValue:value=BOOLEAN;
StringValue:value=NL;
ShallOperator:
	('SHALL'|'shall') elements=General;
MayOperator:
	("MAY"|'may') action1=General ('OR'|'or') action2=General;
EventuallyOperator:
	('EVENTUALLY'|'eventually') element=General;
BeforeOperator:
	('BEFORE'|'before') event=NL other=General;
AfterOperator:
	('AFTER'|'after') event=NL other=General;
InOperator:
	('IN'|'in') t=NL other=General;
AsCloseOperator:
	('AS' 'CLOSE' 'AS' 'POSSIBLE' 'TO'|'as' 'close' 'as' 'possible' 'to') ForQ=NL;
AsOperator:
	AsEarlyOperator|AsLateOperator|AsManyOperator|AsFewOperator;
AsEarlyOperator:
	('AS' 'EARLY' 'AS' 'POSSIBLE'|'as' 'early' 'as' 'possible') value=General;
AsLateOperator:
	('AS' 'LATE' 'AS' 'POSSIBLE'|'as' 'late' 'as' 'possible') value=General;
AsManyOperator:
	('AS' 'MANY'|'as' 'many') (element=NL)? ('AS' 'POSSIBLE'|'as' 'possible') value=General;
AsFewOperator:
	('AS' 'FEW'|'as' 'few') (element=NL)? ('AS' 'POSSIBLE'|'as' 'possible') value=General;
And on the generator, I was able to do the following:
override void doGenerate(Resource resource, IFileSystemAccess2 fsa, IGeneratorContext context) {
		// criamos um arquivo em separado para cada requisito
		var counter = 1
		for (e : resource.allContents.toIterable.filter(Requirement)) {
			fsa.generateFile("relaxExpressions" + counter + ".exp", e.compile)
			counter++
	def compile(Requirement r) '''
		«FOR f : r.root»
			«f.compileGeneral»
		«ENDFOR»
	def compileGeneral(General g) '''
		«IF g.rest != null»
			«g.rest.compileRest »
		«ENDIF»
	def compileRest(Rest r) '''
		«IF r.eContainer.class.equals(Primitive) »
			aa
		«ENDIF»
My doubts in the compileRest method, how do I deal with a "Rest" rule that does not have any internal variables in grammar, only directs to other rules?
Also, how do I get information from the left recursion treated in the General rule in grammar?
And last one, am I doing it the right way?
Thank you for your attention.
Re: Problems with code generation [message #1749469 is a reply to message #1749448] Wed, 07 December 2016 01:23 Go to previous messageGo to next message
i recommend you two things.
first have a look at the inferred metamodel classes and their type hierarchy
there you will see something like
Rest
  - AsOperator
  - Primitive
    - StringValue
    - BooleanValue
and
General
 - UntilOperator
so with some instanceof-ing you would be able to the distinction
or have a look at the feature of Xtend that is called dispatch methods, that allows you to write something like
	def dipatch compileGeneral(General g) '''
		//TODO
	def dipatch compileGeneral(UntilOperator g) '''
		//TODO
	def dipatch compileRest(Rest r) '''
		// TODO
	def dipatch compileRest(BooleanValue r) '''
		// TODO
	def dipatch xompileRest(StringValue r) '''
		// TODO
	def dipatch compileRest(AsOperator r) '''
		// TODO
update: added missing dipatch keywords
[Updated on: Wed, 07 December 2016 08:25] by Moderator
Re: Problems with code generation [message #1749503 is a reply to message #1749469] Wed, 07 December 2016 08:22 Go to previous messageGo to next message
Hi Luiz,
I also recommend the dispatch methods for your case.
To add to Christian's reply, they than have to look like
	def dispatch compileRest(Rest r) '''
		// TODO
	def dispatch compileRest(BooleanValue r) '''
		// TODO
	def dispatch compileRest(StringValue r) '''
		// TODO
	def dispatch compileRest(AsOperator r) '''
		// TODO
regards,
Christian
Christian Dietrich wrote on Wed, 07 December 2016 07:23
Rest
  - AsOperator
  - Primitive
    - StringValue
    - BooleanValue
and
General
 - UntilOperator
		//TODO
	def compileGeneral(UntilOperator g) '''
		//TODO
		// TODO
	def compileRest(BooleanValue r) '''
		// TODO
	def compileRest(StringValue r) '''
		// TODO
	def compileRest(AsOperator r) '''
		// TODO
Re: Problems with code generation [message #1751364 is a reply to message #1749503] Mon, 09 January 2017 07:00 Go to previous messageGo to next message
Hi guys, thanks for the tips.
I did as you've said, to using the dispatcher, it looked like this:
		«IF g.rest != null»
			«g.rest.compileRestRule »
		«ENDIF»
	def compileRestRule(Rest r) '''
		«r.rule.compileRest»
	//sobreposicao das regras contidas em Rest
	def dispatch compileRest(Primitive p)'''
		«p.compilePrimitive»
	def dispatch compileRest(ShallOperator s)'''
		SHALL
		«s.elements.compileGeneral»
	//compilar primitivos
	def dispatch compilePrimitive(BooleanValue b)'''
		«b.value»
	def dispatch compilePrimitive(StringValue s)'''
		«s.value.trim»
But now in the compileRest (Primitive p) method, the following error is displayed: Unhandled parameter types: [null]
Apparently the parameter is coming with null value, any idea why this happens?
Thank you.
Re: Problems with code generation [message #1751365 is a reply to message #1751364] Mon, 09 January 2017 07:08 Go to previous messageGo to next message
simply debug it? then you should see where it comes from
Re: Problems with code generation [message #1752291 is a reply to message #1751365] Fri, 20 January 2017 11:30 Go to previous message
I was able to solve the problems, thank you for the tips.
Previous Topic:Problem with Cross-Referencing and ProxyURIs
Next Topic:[XTEXT] How to display specific error for special characters?
Current Time: Sun Jul 20 18:23:56 EDT 2025
Powered by FUDForum. Page generated in 0.04151 seconds
