Home » Modeling » TMF (Xtext) » How to infer a method with generics?(How to create a JvmOperation with generics)
How to infer a method with generics? [message #1749037] Thu, 01 December 2016 06:14 Go to next message
I am trying to enhance my DSL which is derived from XbaseWithAnnotations to enable the use of generic method.
The user should write something like this:
op <T> doSomething (T arg)
println("Hallo"+T)
1.) Is there a nice way to do this? I am sure I am not the first one who tries to do something like this. but I could not find any example.
2.) I could not figure out how to tell the JvmOpertation about the generics.
Any hint welcome
Thank you
Re: How to infer a method with generics? [message #1749049 is a reply to message #1749037] Thu, 01 December 2016 07:52 Go to previous messageGo to next message
In YourDslJvmModelInferrer you'll need:
    @Inject private org.eclipse.xtext.common.types.TypesFactory typesFactory
    @Inject private org.eclipse.xtext.common.types.util.TypeReferences references
Then when iterating over features you need to create type parameter first:
    val tp = typesFactory.createJvmTypeParameter()
    tp.name = "T"
And then add this type parameter to JvmOperation instance and also as type of parameter.
        members += operation.toMethod(operation.name, references.createTypeRef(tp)) [
            typeParameters += tp
            parameters += params.head.toParameter(p.name, references.createTypeRef(tp))
[Updated on: Fri, 02 December 2016 07:08] by Moderator
Re: How to infer a method with generics? [message #1749064 is a reply to message #1749049] Thu, 01 December 2016 09:22 Go to previous messageGo to next message
Thanks, but is works only for one Method
        members += operation.toMethod(f.name, references.createTypeRef(tp)) [
       members += operation.toMethod(f.name+"X", references.createTypeRef(tp)) [
Does not work. "Cannot make a static reference to the non-static type T"
I need to create an Interface and an Implementation so I have to use it twice. (I tried tp.cloneWithProxies, but no success)
Re: How to infer a method with generics? [message #1749071 is a reply to message #1749064] Thu, 01 December 2016 09:59 Go to previous messageGo to next message
Just create one type parameter per operation. Then they can be named the same.
Re: How to infer a method with generics? [message #1749074 is a reply to message #1749071] Thu, 01 December 2016 10:39 Go to previous messageGo to next message
I do not understand.
Creating the genericTypes twice does not solve the problem
	val genericTypes = method.createJvmTypeParameter()
	members += method.toMethod(method.declaration.methodName, method.type().cloneWithProxies) [
		genericTypes.forEach[tp|
			typeParameters += tp.cloneWithProxies
	val genericTypesX = method.createJvmTypeParameter()
	members += method.toMethod(method.declaration.methodName+"X", method.type().cloneWithProxies) [
		genericTypesX.forEach[tp|
Re: How to infer a method with generics? [message #1749075 is a reply to message #1749071] Thu, 01 December 2016 10:39 Go to previous messageGo to next message
Re: How to infer a method with generics? [message #1749148 is a reply to message #1749075] Fri, 02 December 2016 05:21 Go to previous messageGo to next message
You're not creating the generic types twice: you're cloning them
Re: How to infer a method with generics? [message #1749150 is a reply to message #1749148] Fri, 02 December 2016 05:48 Go to previous messageGo to next message
calls the method like suggested by Alex
    tp.name = "T"
So for every generic parameter I call the code.
I my case this should create a new JvmTypeParameter instance for each JvmOperation.
Mybe this shows it better:
	tp.name = "T"
	val tpX = typesFactory.createJvmTypeParameter()
	tpX.name = "T"
		typeParameters += tpX.cloneWithProxies
results in an error: Cannot make a static reference to the non-static type T
Re: How to infer a method with generics? [message #1749152 is a reply to message #1749150] Fri, 02 December 2016 06:14 Go to previous messageGo to next message
Why are you cloning the type parameters?
typeParameters += tp // .cloneWithProxies
Please inspect the working example from above.
After reading your first post once again, I'm not sure which signatures you are expecting to be created.
[Updated on: Fri, 02 December 2016 06:15] by Moderator
Re: How to infer a method with generics? [message #1749154 is a reply to message #1749152] Fri, 02 December 2016 06:51 Go to previous messageGo to next message
Thank you for your patience.
I have create a tiny dsl which shows the problem.
When you run the test case you get the error message.
Re: How to infer a method with generics? [message #1749156 is a reply to message #1749154] Fri, 02 December 2016 07:14 Go to previous messageGo to next message
Okay, I had a look at your test.
In addition to my last comment: please also consider to use a type reference to the actual type parameter as return type of the inferred operation. Cf. example from above. The relevant line is:
  members += operation.toMethod(operation.name, references.createTypeRef(typeParameterT)) [ ...
Re: How to infer a method with generics? [message #1749160 is a reply to message #1749156] Fri, 02 December 2016 08:12 Go to previous messageGo to next message
I have change to
	def dispatch void infer(Class element, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
		acceptor.accept(element.toClass("my.class."+element.name))[
			element.methods.forEach[method|
				tp.name = method.generic
				members += method.toMethod(method.name, references.createTypeRef(tp))[
				tpX.name = method.generic
				members += method.toMethod(method.name+"X", references.createTypeRef(tpX))[
but still the same: "Cannot make a static reference to the non-static type T"
Re: How to infer a method with generics? [message #1749312 is a reply to message #1749160] Mon, 05 December 2016 06:20 Go to previous messageGo to next message
In your grammar, you say
Method:
	'<' generic=ValidID '>' ...
as such you don't give Xbase a hint that this is a type parameter.
You have to write
Method:
	'<'generic=JvmTypeParameter'>' ...
instead. You can use this type parameter directly in the inferrer, i.e.
	members += method.toMethod(method.name, method.type)[
		typeParameters += method.generic
	members += method.toMethod(method.name+"X", method.type)[
Re: How to infer a method with generics? [message #1771289 is a reply to message #1749312] Wed, 23 August 2017 13:15 Go to previous message
Sorry but I have to reopen this thread.
I have learned a lot and created a tiny dsl
grammar lutte.typedmethodParameter.LUTTE1 with org.eclipse.xtext.xbase.annotations.XbaseWithAnnotations
generate lUTTE1 "http://www.typedmethodParameter.lutte/LUTTE1"
Model:
	'BusinessClass' name = ValidID
	operations += Operation*
Operation:
	typedParameters += TypedParameter* 'op' operationType = JvmTypeReference name = ValidID '(' parameters+=JvmFormalParameter(','parameters+=JvmFormalParameter)*')'
	body = XBlockExpression
TypedParameter:
	'<'typedParameter = JvmTypeParameter'>'
with Inferer
 * generated by Xtext 2.12.0
package lutte.typedmethodParameter.jvmmodel
import com.google.inject.Inject
import lutte.typedmethodParameter.lUTTE1.Model
import org.eclipse.xtext.xbase.jvmmodel.AbstractModelInferrer
import org.eclipse.xtext.xbase.jvmmodel.IJvmDeclaredTypeAcceptor
import org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder
class LUTTE1JvmModelInferrer extends AbstractModelInferrer {
	@Inject extension JvmTypesBuilder
	def dispatch void infer(Model element, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
		acceptor.accept(element.toClass("test."+element.name))[
			element.operations.forEach[op|
				members += op.toMethod(op.name, op.operationType.cloneWithProxies)[
					op.typedParameters.forEach[parameter|
						typeParameters += parameter.typedParameter
					op.parameters.forEach[parameter|
						parameters += parameter.cloneWithProxies
					body = op.body
				members += op.toMethod(op.name+"2", op.operationType.cloneWithProxies)[
a test case
package lutte.typedmethodParameter.tests
import com.google.inject.Provider
import java.util.ArrayList
import org.eclipse.xtext.generator.InMemoryFileSystemAccess
import org.eclipse.xtext.resource.XtextResourceSet
import org.eclipse.xtext.testing.InjectWith
import org.eclipse.xtext.testing.XtextRunner
import org.eclipse.xtext.testing.util.ParseHelper
import org.eclipse.xtext.xbase.compiler.JvmModelGenerator
import org.junit.Assert
import org.junit.Test
import org.junit.runner.RunWith
import org.eclipse.emf.common.util.URI
@RunWith(XtextRunner)
@InjectWith(LUTTE1InjectorProvider)
class LUTTE1ParsingTest {
	@Inject
	ParseHelper<Model> parseHelper
	@Inject private Provider<XtextResourceSet> resourceSetProvider;
	@Inject private JvmModelGenerator generator;
	@Test
	def void loadModel() {
		val resourceSet = resourceSetProvider.get
		resourceSet.classpathURIContext = this
		val result = parseHelper.parse('''
			BusinessClass Test
			<T> op T test(T t)
				t
		''', URI.createURI("test/Test.lutte1"), resourceSet)
		Assert.assertNotNull(result)
		Assert.assertTrue(result.eResource.errors.isEmpty)
        val fsa = new InMemoryFileSystemAccess()
        val resources = new ArrayList(resourceSet.resources)
		resources.forEach[resource|
	        generator.doGenerate(resource, fsa)
        fsa.allFiles.entrySet.forEach[entry|
        	println(entry.key)
        val file = fsa.textFiles.get("DEFAULT_OUTPUTtest/Test.java").toString;
		Assert.assertEquals('''package test;
@SuppressWarnings("all")
public class Test {
  public <T> T test(final T t) {
    return t;
  public <T> test2(final T t);
'''.toString.remove('\r'), file)
	def String remove (String from, String value)
		return from.replaceAll("("+value+")", "");
with the result
org.junit.ComparisonFailure: expected:<... t;
  public [<T> test2(final T] t);
> but was:<... t;
  public [? test2(final ?] t);
	at org.junit.Assert.assertEquals(Assert.java:115)
	at org.junit.Assert.assertEquals(Assert.java:144)
	at lutte.typedmethodParameter.tests.LUTTE1ParsingTest.loadModel(LUTTE1ParsingTest.java:98)
What is it I am missing?
I used xtext 2.12.0 .
Previous Topic:How to enable running functionality in a new dsl
Next Topic:SyntaxErrorMessageProvider custom implementation
Current Time: Sun Jul 20 12:43:36 EDT 2025
Powered by FUDForum. Page generated in 0.12315 seconds
