Home » Modeling » TMF (Xtext) » XText Formatter: organize elements
XText Formatter: organize elements [message #1748617] Fri, 25 November 2016 05:28 Go to next message
Is there a way to organize elements during formatting?
For example if I have imports
import A.A
import B.C
import A.B
import B.B
after formatting I want to get to following result
import A.A
import A.B
import B.B
import B.C
Re: XText Formatter: organize elements [message #1748829 is a reply to message #1748617] Tue, 29 November 2016 02:57 Go to previous message
Formatting should only adjust whitespace and not change the semantic model. What you are asking for looks more like an "organize import" clean up.
So, yes, you can do that but not with the formatter. You could for instance change the model and then use the serializer to write it back.
Have a look at the OrganizeImportsHandler here: https://github.com/eclipse/xtext-eclipse/blob/master/org.eclipse.xtext.xbase.ui/src/org/eclipse/xtext/xbase/ui/imports/OrganizeImportsHandler.java#L33
Previous Topic:EMFModelInferrer
Next Topic:Addictional Optional Argument Recognition
Current Time: Sun Jul 20 07:48:07 EDT 2025
Powered by FUDForum. Page generated in 0.03893 seconds
