Server configuration update [message #1748333] |
Tue, 22 November 2016 05:32  |
I followed the instructions at https://wiki.eclipse.org/Eclipse_Oomph_Authoring#Setting_up_WST_Server_Runtime_and_Instances_in_your_Project_Setup to setup my server which worked fine.
Now my project evolved and a new module is contained in the workspace. How can I make sure that the new module is also part of the server instance, because the step 6 below "Server Instance in Servers View" seems only be applied once(!) for each workspace. If the file is afterwards modified in my project setup (in this case to also list the additional module) this change is not propagated to already existing workspaces. Any idea how to force the overwriting of the servers.xml with each execution of the setup task?
FUDForum. Page generated in 0.05320 seconds
