error when installing Snaps 3.0.2 on VTS 3.0.2 [message #759831] |
Wed, 30 November 2011 04:09  |
2011-11-30 00:57:26.651] start-signalling-1 <DE0005I> Started plan 'org.eclipse.virgo.web.tomcat' version '3.0.0'.
[2011-11-30 00:57:26.842] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.snaps' version '3.0.0'.
[2011-11-30 00:57:27.040] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.snaps.api' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.520] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.snaps.core' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.580] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.snaps.api' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.583] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.snaps.core' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.587] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.snaps' version '3.0.0'.
[2011-11-30 00:57:27.605] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.snaps' version '3.0.0'.
[2011-11-30 00:57:27.609] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.snaps.api' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.625] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.snaps.core' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.628] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.snaps.api' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.771] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.snaps.core' version '3.0.2.RELEASE'.
[2011-11-30 00:57:27.775] start-signalling-1 <DE0005I> Started plan 'org.eclipse.virgo.snaps' version '3.0.0'.
[2011-11-30 00:57:27.778] system-artifacts <DE0501E> Cannot deploy artifact from URI ''. Deployment of 'null' URIs is not supported.
[2011-11-30 00:57:27.782] system-artifacts <UR0002E> User region failed while deploying initial artifacts. Shutting down.
[2011-11-30 00:57:27.862] System Bundle Shutdown <KE0010I> Shutdown initiated.
[2011-11-30 00:57:28.005] System Bundle Shutdown <TC0002I> Stopping Tomcat.
[2011-11-30 00:57:31.029] System Bundle Shutdown <TC0003I> Stopped Tomcat.
I am following the snaps installation instructions from the virgo documentation resources.
The log file doesnt have much information about the problem either:
[2011-11-30 00:51:49.840] INFO start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.eclipse.virgo.snaps.core' version '3.0.2.RELEASE'.
[2011-11-30 00:51:49.840] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=org.eclipse.virgo.snaps.core_3.0.2.RELEASE]' popped and set to 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]'
[2011-11-30 00:51:49.844] INFO start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started plan 'org.eclipse.virgo.snaps' version '3.0.0'.
[2011-11-30 00:51:49.847] ERROR system-artifacts org.eclipse.virgo.medic.eventlog.default DE0501E Cannot deploy artifact from URI ''. Deployment of 'null' URIs is not supported.
[2011-11-30 00:51:49.850] ERROR system-artifacts org.eclipse.virgo.medic.eventlog.default UR0002E User region failed while deploying initial artifacts. Shutting down.
[2011-11-30 00:51:49.856] INFO System Bundle Shutdown o.e.v.kernel.dmfragment.internal.ApplicationContextShutdownBean Setting timeout to 0 for proxy 'org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean@557555b8' of application context 'OsgiBundleXmlApplicationContext(bundle=org.springframework.osgi.extender, config=bundleentry://79.fwk389362249/META-INF/spring/extender/kernel-dmfragment-context.xml): startup date [Wed Nov 30 00:51:44 PST 2011]; root of context hierarchy'
FUDForum. Page generated in 0.04605 seconds
