Home » Eclipse Projects » Eclipse 4 » Enable File-->Save when view part is dirty(How to enable File-->Save (Ctrl+S) menu item when a selected view part is set dirty)
Enable File-->Save when view part is dirty [message #1748272] Mon, 21 November 2016 12:39 Go to next message
I'm using Eclipse Neon.1 Release (4.6.1) to develop a plugin which contributes to ide.
A view part has a MDirtyable member which is set "dirty" (here an example):
@Inject
MDirtyable dirty;
	@PostConstruct
	public void createControls(Composite parent) {
		dirty.setDirty(true);
	@Persist
	public void save() {
	  	dirty.setDirty(false);
How can I enable menu item File-->Save (Ctrl+s) and toolbar item in Eclipse ide?
I must define a command "org.eclipse.ui.file.save" in a fragment?
I made another rcp example, defining command "org.eclipse.ui.file.save", handler and menu item, and it works.
How can be enabled File-->Save menu item in a plugin (ide contribution) when a part is set dirty?
Thank you
Re: [workaround] Enable File-->Save when view part is dirty [message #1748460 is a reply to message #1748272] Wed, 23 November 2016 05:40 Go to previous messageGo to next message
I found a workaround:
	@Inject
	ECommandService commandService;
	@Inject
	EHandlerService handlerService;
	@PostConstruct
		handlerService.activateHandler("org.eclipse.ui.file.save", new org.eclipse.e4.ui.internal.workbench.handlers.SaveHandler());
		commandService.getCommand("org.eclipse.ui.file.save").isEnabled();
	@Persist
	public void save(ECommandService commandService) {
Re: Enable File-->Save when view part is dirty [message #1748461 is a reply to message #1748272] Wed, 23 November 2016 05:46 Go to previous message
	@Inject
	MDirtyable dirty;
	@Inject
	@Inject
	@PostConstruct
	@Persist
Previous Topic:.e4xmi eclipse modeling framework (EMF) file
Next Topic:Slow reaction of Eclipse Editors on a Windows VM
Current Time: Sun Jul 20 17:17:09 EDT 2025
Powered by FUDForum. Page generated in 0.03321 seconds
