Installing Eclipse Neon having log file error. [message #1747037] |
Tue, 08 November 2016 13:25  |
following are the logs in the file Eclipse Reporting\eclipse\cofiguration\1478625188661.log and also attached the file alongwith.
!SESSION 2016-11-08 09:01:32.124 -----------------------------------------------
eclipse.buildId=4.6.0.I20160606-1100
java.version=1.8.0_111
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.reporting.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.reporting.product
!ENTRY org.eclipse.equinox.ds 2 0 2016-11-08 09:02:06.202
!MESSAGE [SCR - WorkThread] Timeout occurred! Thread was blocked on processing [QueuedJob] WorkPerformer: org.eclipse.equinox.internal.ds.SCRManager@1e95e666; actionType 1
!ENTRY org.eclipse.equinox.ds 2 0 2016-11-08 09:02:06.327
!MESSAGE [SCR] Enabling components of bundle org.eclipse.ui.trace did not complete in 30000 ms
!ENTRY org.eclipse.core.runtime 4 0 2016-11-08 09:02:11.356
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Unable to acquire the state change lock for the module: osgi.identity; type="osgi.bundle"; version:Version="3.12.0.v20160606-1342"; osgi.identity="org.eclipse.core.runtime"; singleton:="true" [id=194] STARTED [STARTED]
at org.eclipse.osgi.container.Module.lockStateChange(Module.java:337)
at org.eclipse.osgi.container.Module.start(Module.java:401)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.util.concurrent.TimeoutException: Timeout after waiting 5 seconds to acquire the lock.
at org.eclipse.osgi.container.Module.lockStateChange(Module.java:334)
... 8 more
Root exception:
FUDForum. Page generated in 0.08665 seconds
