Home » Eclipse Projects » Oomph » is HTTPS URL supported in oomph.redirection.setups ?
is HTTPS URL supported in oomph.redirection.setups ? [message #1746436] Fri, 28 October 2016 12:52 Go to next message
I have a custom catalog/index hosted in an local server.
When I switch from http:// to https:// Oomph Installer is not able to find the catalogs anymore.
The eclipse-inst.ini looks like this:
-Doomph.redirection.setups=index:/->https://<my-server>/setups/
Should this be supported?
[Updated on: Fri, 28 October 2016 12:54] by Moderator
Re: is HTTPS URL supported in oomph.redirection.setups ? [message #1746447 is a reply to message #1746436] Sat, 29 October 2016 00:54 Go to previous messageGo to next message
Yes definitely this should be supported. I expect it just to work. Certainly I have customer project setups accessed via https that require basic authentication that do just work so in general ECFURIHandlerImpl should handle the required authentication properly...
You could try using -Doomph.setup.ecf.trace=true to get more detailed tracing information printed to System.out so you might be able to see what's going wrong.
Does this server require a user/password for access? Does it return a HTTP_UNAUTHORIZED/401 when accessing a resource without credentials? In my customer project the server is quite funky in that it returns a 404 after providing the correct credentials because the server also relies on cookie that's acquired from visiting the login page. That's supported too, but I've not yet documented how. Please let me know what information you get back for the tracing so I'll be better able to help provide the details (and fix any problems if there are any)...
Re: is HTTPS URL supported in oomph.redirection.setups ? [message #1746448 is a reply to message #1746436] Sat, 29 October 2016 00:55 Go to previous messageGo to next message
Re: is HTTPS URL supported in oomph.redirection.setups ? [message #1746449 is a reply to message #1746448] Sat, 29 October 2016 03:59 Go to previous messageGo to next message
One thing I just noticed debugging proxy related problems is that the prompt for the proxy password that I'm trying to add happens so early in the startup processing that there is no a Shell available yet. So the password prompting is bypassed. I'm quite sure the same thing would happen if the setup itself needs password prompting. So I'm hopeful that improving the proxy handling with proxy password prompting will also fix this problem because with the changes I'm working on, the password prompt will definitely appear. Hopefully that is indeed your problem. An ECF trace from you will still be helpful...
Re: is HTTPS URL supported in oomph.redirection.setups ? [message #1746451 is a reply to message #1746449] Sat, 29 October 2016 04:31 Go to previous messageGo to next message
Thanks Ed.
-Doomph.setup.ecf.trace=true helped a lot.
I can see the SSL certificate validation failed. Most liked this is caused by the usage of a self-signed certificate that we use on this internal server.
Here's the log:
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderExce
ption: unable to find valid certification path to requested target
        at sun.security.ssl.Alerts.getSSLException(Unknown Source)
        at sun.security.ssl.SSLSocketImpl.fatal(Unknown Source)
        at sun.security.ssl.Handshaker.fatalSE(Unknown Source)
        at sun.security.ssl.ClientHandshaker.serverCertificate(Unknown Source)
        at sun.security.ssl.ClientHandshaker.processMessage(Unknown Source)
        at sun.security.ssl.Handshaker.processLoop(Unknown Source)
        at sun.security.ssl.Handshaker.process_record(Unknown Source)
        at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)
        at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)
        at sun.security.ssl.SSLSocketImpl.writeRecord(Unknown Source)
        at sun.security.ssl.AppOutputStream.write(Unknown Source)
        at org.apache.http.impl.io.AbstractSessionOutputBuffer.flushBuffer(AbstractSessionOutputBuffer.java:159)
        at org.apache.http.impl.io.AbstractSessionOutputBuffer.flush(AbstractSessionOutputBuffer.java:166)
        at org.apache.http.impl.AbstractHttpClientConnection.doFlush(AbstractHttpClientConnection.java:272)
        at org.apache.http.impl.AbstractHttpClientConnection.flush(AbstractHttpClientConnection.java:277)
        at org.apache.http.impl.conn.AbstractClientConnAdapter.flush(AbstractClientConnAdapter.java:201)
        at org.apache.http.protocol.HttpRequestExecutor.doSendRequest(HttpRequestExecutor.java:239)
        at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:121)
        at org.apache.http.impl.client.DefaultRequestDirector.tryExecute(DefaultRequestDirector.java:685)
        at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:487)
        at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:863)
        at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
        at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1077)
        at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:618)
        at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:885)
        at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576)
        at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:106)
        at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl.createInputStream(ECFURIHandlerImpl.java:539)
        at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
        at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1269)
        at org.eclipse.oomph.setup.internal.core.util.ResourceMirror$LoadJob.perform(ResourceMirror.java:221)
        at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:416)
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find vali
        at sun.security.validator.PKIXValidator.doBuild(Unknown Source)
        at sun.security.validator.PKIXValidator.engineValidate(Unknown Source)
        at sun.security.validator.Validator.validate(Unknown Source)
        at sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source)
        at sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source)
        at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source)
        ... 30 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
        at sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source)
        at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source)
        at java.security.cert.CertPathBuilder.build(Unknown Source)
        ... 36 more
Is there a way to disable the SSL verification in order to avoid to have to add the certificate to the list of trusted certificates?
Re: is HTTPS URL supported in oomph.redirection.setups ? [message #1746453 is a reply to message #1746451] Sat, 29 October 2016 06:34 Go to previous messageGo to next message
This is very low level. I don't know about that. I tried Googling "java disable certificate validation system property" and found some stackoverflow questions. All of these things suggest it's a bad idea to try to disable such checks with suggestions about importing the certificate so that it's considered valid.
Re: is HTTPS URL supported in oomph.redirection.setups ? [message #1746458 is a reply to message #1746453] Sat, 29 October 2016 11:49 Go to previous messageGo to next message
Yes, that's true, it's a bad idea to disable certificates in a generic way, but having to import it in every JRE we use (remember, we have a new JRE version every 3 months), that's not very practical.
Anyway, I imported the certificate and now it works fine, so I need to figure out how to workaround this, in order to not force users to install the certificate every time they change the JRE. Maybe I could distribute the Installer zip with a pre-configured JRE inside.
Thanks for the support.
Re: is HTTPS URL supported in oomph.redirection.setups ? [message #1746469 is a reply to message #1746458] Sun, 30 October 2016 05:22 Go to previous messageGo to next message
Did you use keytool to import it? Perhaps we could provide a way to automatically import a certificate into the JRE of the installer and into any of the other JREs that Oomph discovers...
Re: is HTTPS URL supported in oomph.redirection.setups ? [message #1756320 is a reply to message #1746436] Wed, 15 March 2017 07:08 Go to previous messageGo to next message
did you solved the problem already?
I figured out, that this problem does not occur on my own machine but only on my colleagues one. I have no idea how to figure out what we do differently.
Re: is HTTPS URL supported in oomph.redirection.setups ? [message #1756321 is a reply to message #1756320] Wed, 15 March 2017 07:28 Go to previous messageGo to next message
Do you perhaps have a newer JRE installed than your colleagues? A newer JRE/JDK might well include more recognized root certificates; I know that solved one problem like this for me testing market place client listings...
Re: is HTTPS URL supported in oomph.redirection.setups ? [message #1756346 is a reply to message #1756321] Wed, 15 March 2017 12:04 Go to previous message
Thank you for your hint, Ed. This exactly solves the problem Smile
Previous Topic:Toggle Source/Header not working
Next Topic:Problems migrating to Neon
Current Time: Sat Jul 19 16:36:26 EDT 2025
Powered by FUDForum. Page generated in 0.04456 seconds
