Home » Eclipse Projects » EclipseLink » Lazy loaded relation after detach with cascade detach not detached.
icon5.gif  Lazy loaded relation after detach with cascade detach not detached. [message #1745853] Tue, 18 October 2016 08:24 Go to next message
I'm not sure if this is a bug or correct behaviour. Imho it is wrong but I thought i ask here before filing a bug report.
Explanation:
Two entities Book and Page
@Entity
public class Book extends AbstractSimpleEntity implements Serializable {
	private static final long serialVersionUID = 1L;
	@OneToMany(mappedBy = "book", cascade = CascadeType.ALL, orphanRemoval = true, fetch = FetchType.LAZY)
	@OrderColumn(name = "position")
	@Getter
	@Setter
	protected List<Page> pages = new ArrayList<>();
@Entity
@NoArgsConstructor(access = AccessLevel.PROTECTED)
public class Page extends AbstractSimpleEntity implements Serializable {
	@Getter
	@ManyToOne
	protected Book book;
	@Getter
	@Setter
	private boolean done = false;
	public Page(Book book) {
		this.book = book;
And this function where the result is not what i expected
	private static void editFirstBookPage(Long bookId) {
		EntityManager em = EmfHandler.getEM();
		try {
			em.getTransaction().begin();
			Book book = em.find(Book.class, bookId);
			em.detach(book);
			List<Page> pages = new ArrayList<>(book.getPages());
			// Uncomment this to workaround the problem
			// for (Page page : pages) {
			// em.detach(page);
			pages.get(0).setDone(true);
			Book origBook = em.find(Book.class, bookId);
			em.refresh(origBook);
			origBook.setPages(pages); // thats where done flag is reseted
			// book = em.merge(book); //Same Problem with merge
			em.flush();
			em.getTransaction().commit();
			LOG.info("Updated Pages");
		} finally {
			if (em.getTransaction().isActive())
				em.getTransaction().rollback();
			EmfHandler.disposeEM(em);
Right after detaching the book entity I access the pages relation and because CascadeType.DETACH (CascadeType.ALL) I assumed, that the pages are also detached, but they are not. So setting pages on origBook refreshes the pages too because it is also CascadeType.REFRESH and so my done flag set back to false.
I can provide a maven project demonstrating this if someone is wants to test it.
What do you think? Is this a bug or correct behaviour?
Raffael
Re: Lazy loaded relation after detach with cascade detach not detached. [message #1746305 is a reply to message #1745853] Wed, 26 October 2016 11:55 Go to previous message
File a bug, but the behavior is what I expect due to EclipseLink's lazy relationship fetching while the context is still alive. The only option for this to work as you would expect is that after an entity is detached, unfetched lazy relationships would not be reachable and accessing that relationship would require throwing an exception - the entity is detached from the context so it really should have no way of fetching lazy relationships. An exception though isn't likely what you want - well, I don't in my projects, so I'm happy to live with this behavior and use prefetching options over required lazy relationships before calling detach or using other options like serialization that make those relationships unreachable.
Previous Topic:How to create DB2 tables from entitys
Next Topic:Metamodel not being created until after first use
Current Time: Sun Jul 20 09:15:25 EDT 2025
Powered by FUDForum. Page generated in 0.03108 seconds
