Home » Eclipse Projects » Oomph » Edit Preset Variable
Edit Preset Variable [message #1745912] Wed, 19 October 2016 05:36 Go to next message
How can I add a variable which the user can edit and is predefined by an environment variable?
Lets say I have the environment variable myvar with the value "sample value".
At the beginning of the installation I want to show a text field with the value of the environment variable i.e. "sample value". The user should be able to edit the value.
I tried so far to use the environment variable as value attribute of a setup:VariableTask but then oomph just does not ask the user anymore.
Re: Edit Preset Variable [message #1745916 is a reply to message #1745912] Wed, 19 October 2016 05:55 Go to previous messageGo to next message
Refer to your environment variable in the Variable Task's default value property:
<xmi:XMI xmi:version="2.0"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0">
  <setup:VariableTask
      name="author.name"
      defaultValue="${user.name}"
      label="Author name"/>
  <setup:EclipseIniTask
      option="-Dcom.foo.author.name"
      value="=${author.name}"
      vm="true"/>
</xmi:XMI>
Re: Edit Preset Variable [message #1745925 is a reply to message #1745916] Wed, 19 October 2016 07:48 Go to previous message
Your solution works like expected.
Thanks.
Previous Topic:Reference external setup tasks through href
Next Topic:control some initial view settings
Current Time: Sat Jul 19 15:44:22 EDT 2025
Powered by FUDForum. Page generated in 0.04935 seconds
