Home » Modeling » TMF (Xtext) » Xtext editor backed by XMI resource
Re: Xtext editor backed by XMI resource [message #1745952 is a reply to message #1745942] |
Wed, 19 October 2016 14:05   |
Thanks for your responses
Christian Dietrich wrote on Wed, 19 October 2016 16:47if the model changes, how do you know the objects itself does not change?
what differs a move rename remove and readd?
is it just the position inside the model?
Christian, I'm not sure I understand the first question about the model changing and the objects changing. Could you please elaborate?
Re: differentiating between move-rename and remove-readd, yes. That is a limitation that I'm okay with. Users would have to apply refactors to preserve the identify of things.
Not sure I understand the position question either. I don't identify objects by position and I don't intend to do so. Moving things around, as long as it preserves the assigned id, should have no effect.
Ed Willink wrote on Wed, 19 October 2016 16:59Hi
What you say is certainly possible. With Xtext, you have a similar problem as with the UML Model Editor that trashes any pre-existing xmi:ids. You therefore need to ensure that you automatically assign new xmi:ids during Resource.save. For these to be useful they should be deterministic, typically dependent on ancestor class+name/position path. For an arbitrary metamodel this can result in unpleasantly long names. If you have a good understanding on the limitations on your metamodel you can design something much more compact. You can find a variety of semantic xmi:id assigners for UML and OCL in the Eclipse OCL project.
Ed Willink
Ed,
My current approach consists on adding a ID attribute to every metaclass of my .ecore. Upon Resource.save I assign UUIDs to the objects without an ID. Note that I don't rely on xmi:ids because I want to access the ids at the model level. Not sure if it is possible with xms:ids, to be honestly; any ideas are welcome.
When I load the resource, I load my root object from the xmi (with the ids) and pass it to Xtext (right now, by serializing the model and parsing it back, which is a huge hack, but XtextDocumentProvider uses IParserResults)
I believe this option should have deterministic ids, as long as Xtext knows which nodes in the textual AST refer to which EObjects in the model, which I think it does; test pending.
To give some more details, I'm subclassing the following classes:
XtextResource: to override the doSave and doLoad methods. I serialize the model as xmi and write it to the output stream of model.myDsl file. Currently working on the doLoad to read the xmi file and expose it as text to the editor.
XtextDocumentProvider: to override the doSave and 1) add missing IDs and 2) call Resource.save (otherwise it stores the text in the mode.myDsl file directly, no Resource.save involved). I'm also working on the doLoad here, currently the xmi data is being exposed in the editor, not sure why yet.
ITransientValueService: I need to let Xtext know that my ID attribute is transient so that Serialization doesn't fail, even tho it is not marked as transient in the ecore file (we want to store the id attribute in the xmi but not in the textual representation)
In short, I want to implement some poor man's approach to projectional editing with Xtext. I understand that caveats my apply. Is this approach going in the right direction?
That said, if any of this work may be interesting to have as part of Xtext, I'd be happy to contribute back. I'd appreciate feedback about the design regardless.
Re: Xtext editor backed by XMI resource [message #1745964 is a reply to message #1745953] |
Wed, 19 October 2016 19:32   |
Thanks again for your responses and your clarifications!
Ed Willink wrote on Wed, 19 October 2016 18:41Hi
IMHO, UUIDs are only useful for write-once models. Not really your use case.
If by adding an ID, you also incorporate the ID in the grammar then the problem is trivial, and your source text is very ugly.
If the ID does not appear in the grammar, then you might as well use xmi:id. It can be accessed from the model level by a helper function.
Ed Willink
Yes, the IDs won't show in the grammar. I'll look into using xmi:ids.
Not sure why UUIDs won't be useful. If I can make sure that a UUID is assigned once and it stays the same for a given object in my model (the editor is the part that may give me more trouble here).
Christian Dietrich wrote on Wed, 19 October 2016 18:57what i meant:
since xtext reparses all the time and does no model merge you cannot distinguish
a rename from a add + remove
=> it will be hard to track this inside the IDs
=> basically the ids have to be type/position based
Ah!, the part where Xtext reparses each time is the one I didn't get to experience yet (still working on it). If that is the case, yes, it will be problematic. Maybe it can be workaround?
Sven Efftinge wrote on Wed, 19 October 2016 21:18Hi Luis,
This is a really hard problem to solve.
There is no way to keep something like a UUID across sessions if you don't persist them somehow.
The closest you get is to use something like EMF compare to try to identify equal objects based on their state and position.
My recommendation is to reconsider the requirement of being resilient to name changes. Names are very natural identifiers.
Sven
Hi Sven,
The ids will be stores across sessions. That's why I want to store the model as xmi, so that I can add the ids before saving.
Funny you mention EMF Compare. The reason I want the stable IDs is so that EMF compare works for my use case.
The requirement of a stable id other than name is legitimate. I want to have a model that acts a a master model. I want to create derived models from the master, which are effectively a clone of the master plus some tweaks. The information I want to keep around is the master model itself and a list of changes to the master so that, when applying them, it yields the child. The master and the child can both rename a given object with distinct names. After that, I want to keep being able to map the object in the master model to the object in the child model. Since names are different in both models, I can't map them.
It is a hard problem to solve, at least in the context of pure textual representations. If the editor reparses the text on every change, creating a new model, then there isn't much to do. On the other hand, if the editor issues changes to the the underlying (and existing model), then it could work. Not 100% sure how it actually works, I guess I'll find out soon enough
[Updated on: Wed, 19 October 2016 19:33] by Moderator
Re: Xtext editor backed by XMI resource [message #1819421 is a reply to message #1745990] |
Tue, 14 January 2020 19:12   |
I'm interested in preserving object IDs for the same reason. Right now I'm preserving xml:id information in a separate properties file where the key is the fully qualified name (FQN) of the object and the value is the xmi:id. I already use this approach to recreate an XMI file with preserved IDs from an xtext file by loading the xtext file into an XTextResource, then converting that to an XMIResource with useUUID() overridden to return true. Once the resource is converted, I then replace the generated UUIDs with the xmi:ids preserved in the separate properties file.
I would like to extend this capability to support refactor/rename in Eclipse while preserving the xmi:id of each EObject. Tell me if the following makes sense:
modify doLoad to load the hidden properties file associated with each xtext file. After the xtext is parsed and the AST created, update the ids of all the EObjects with the information from the properties file. When a refactor/rename is done, preserve the EObjects and their stored ids but change the name. I then update the properties file to replace the key value pair with the old FQN with a pair using the new FQN. If I can't preserve the EObjects (because XText wants to reparse the entire file and create all new EObjects), I could trap the refactor/rename event, convert the AST back to XMLResource, do the rename there, update the properties file, and then convert back to XTextResource.
This does require cloning the properties file whenever the xtext file is cloned but I consider that a minor inconvenience if the rest of it works.
Does this make sense? Or is there something significant that I'm not thinking of?
Current Time: Sat Jul 19 20:08:12 EDT 2025
Powered by FUDForum. Page generated in 0.03596 seconds
