Home » Modeling » TMF (Xtext) » howto bind "«" and "»" to keys in eclipse(I need "«" and "»" even inside of strings in my DSL, how can I provide itto my customers?)
howto bind "«" and "»" to keys in eclipse [message #1745538] Wed, 12 October 2016 05:20 Go to next message
In my DSL, I have to handles some wildcards inside of strings.
To avoid conflichs with normal text, I decided to enclose these in "«" and "»".
The only issue is that the user has to enter these characters when editing his DSL file.
ALT0171 and ALT0187 doesn't seem the best way to do it, but I can not provide some Editor Templates inside of a string.
So is there any (minimal effort, because I'm still a newbie in eclipse) alternative like:
hit "CTRL-<" to enter "«" ?
I think I saw this feature when I edit my xxxGenerator.xtend
TIA, Uli
[Updated on: Wed, 12 October 2016 05:24] by Moderator
Re: howto bind "«" and "»" to keys in eclipse [message #1745546 is a reply to message #1745538] Wed, 12 October 2016 07:24 Go to previous messageGo to next message
Xtend uses guillemets and I think that it was a good design decision however typing them is a nightmare. I have Googled occasionally for help and found rather confusing documentation, certainly the Xtend documentation is not helpful. It seems that part of the problem is Windows-specific and maybe even keyboard-specfic and so simple prefixes don't work for me. I resort to copy-and-paste from a file where the guillemets exist.
It would be nice if Xtend introduced some clear short cuts.
Ed Willink
Re: howto bind "«" and "»" to keys in eclipse [message #1745569 is a reply to message #1745546] Wed, 12 October 2016 11:04 Go to previous messageGo to next message
Hi Ed,
there is some hope because when I edit an XTEND file, typing CTRL-< will result in a "«" (hip hip hooorayyyy!)
The question is only how I can activate the same functionality inside of my little DSL editor.
Perhaps some insider may give us some clue what needs to be done.
Re: howto bind "«" and "»" to keys in eclipse [message #1745570 is a reply to message #1745546] Wed, 12 October 2016 11:04 Go to previous messageGo to next message
Hi Ed,
TIA, Uli
Re: howto bind "«" and "»" to keys in eclipse [message #1745575 is a reply to message #1745570] Wed, 12 October 2016 12:10 Go to previous messageGo to next message
do you mean
<extension
         point="org.eclipse.ui.bindings">
      <key
            contextId="org.eclipse.xtend.ide.XtendEditorScope"
            schemeId="org.eclipse.ui.defaultAcceleratorConfiguration"
            sequence="M1+&lt;"
            commandId="org.eclipse.xtend.ide.insertLeftGuillemet">
      </key>
      <key
            sequence="M1+&gt;"
            commandId="org.eclipse.xtend.ide.insertRightGuillemet">
      </key>
Re: howto bind "«" and "»" to keys in eclipse [message #1745601 is a reply to message #1745575] Thu, 13 October 2016 00:49 Go to previous messageGo to next message
Hi Christian,
that looks pretty promising as a start. I will experiment how this can be converted to work in mydsl example.
Thanks a lot, Uli
P.S: I found in the github the plugin.xml as well as the Handler under
xtext-xtend/org.eclipse.xtend.ide/src/org/eclipse/xtend/ide/edit/InsertStringHandler.java
Now I have to find out how to transfer that to my own little mydsl example project
[Updated on: Thu, 13 October 2016 04:09] by Moderator
Re: howto bind "«" and "»" to keys in eclipse [message #1746510 is a reply to message #1745601] Mon, 31 October 2016 08:58 Go to previous message
as some alternative, one can create some dynamic template as described in https://www.eclipse.org/forums/index.php?t=msg&th=297566&goto=870958&#msg_870958
Previous Topic:Error when running MWE2 file
Next Topic:Restrict scope but still do it accross multiple files
Current Time: Sun Jul 20 17:18:47 EDT 2025
Powered by FUDForum. Page generated in 0.04330 seconds
