Home » Eclipse Projects » Oomph » Update an already eclipse installed through oomph
Update an already eclipse installed through oomph [message #1745272] Fri, 07 October 2016 03:51 Go to next message
I used a specific setup to install my fully customized java EE neon.
I sent this setup file to a colleague of mine and he managed to install the very same eclipse setup, which is great.
Now, I added a new P2 Director in my setup, and installed a new eclipse plugin.
I sent my setup file to my colleague, and I was expecting that his eclipse would automatically upgrade itself, so that the new plugin would be installed on his installation. It didn't.
He then tried "Help/Perform Setup tasks", and it didn't installed the plugin neither.
So what's wrong ? Did I misunderstand oomph behaviour ? Did I miss something ?
Thank you.
dom
Re: Update an already eclipse installed through oomph [message #1745312 is a reply to message #1745272] Fri, 07 October 2016 08:34 Go to previous messageGo to next message
Comments inline below.
Dominique Jean-Prost wrote on Fri, 07 October 2016 03:51
How did you send it, as an attachment and then he copied it somewhere and used it? What kind of setup? A project setup?Quote:
Did he put it where it exactly replaced the setup he's currently using?Quote:
Thank you.
dom
Generally the best way to share it to maintain the setup on a website somewhere and have people point directly as that setup with a URL. Then you can change what's at that URL and everyone will see the changes. But I don't know how you guys exchanged setup, and more specifically where he put his the first time and where he put it the second time.
Re: Update an already eclipse installed through oomph [message #1745315 is a reply to message #1745312] Fri, 07 October 2016 08:38 Go to previous messageGo to next message
No Message Body
Re: Update an already eclipse installed through oomph [message #1745331 is a reply to message #1745312] Fri, 07 October 2016 09:34 Go to previous messageGo to next message
Hello Ed,
I originally sent the project setup file to him by email. He copied this file in his file system, and installed eclipse with this.
I then sent it after my change, with a new content. He saved this file at the very same place, but nothing happened when using "perform setup tasks". Do you confirm it should have installed the new plugin ?
I will have a look to how I can put the setup file in a website so that it's easier to maintain.
Dom
Re: Update an already eclipse installed through oomph [message #1745368 is a reply to message #1745331] Sat, 08 October 2016 14:01 Go to previous message
The same (folder) location is not sufficient. You must also use the same file name.
In Eclipse, you can open the setup file actually used (Navigate->Open Setup-><theProject>), or you double check the list of tasks you see when manually triggering an update (Help->Perform Setup Task). Check there, whether your changes are actually present.
Alex
Previous Topic:Installer says that restart needed but I think it is not
Next Topic:Linked resources are not supported by this application.
Current Time: Sat Jul 19 14:28:51 EDT 2025
Powered by FUDForum. Page generated in 0.03378 seconds
