Update an already eclipse installed through oomph [message #1745272] |
Fri, 07 October 2016 03:51  |
I used a specific setup to install my fully customized java EE neon.
I sent this setup file to a colleague of mine and he managed to install the very same eclipse setup, which is great.
Now, I added a new P2 Director in my setup, and installed a new eclipse plugin.
I sent my setup file to my colleague, and I was expecting that his eclipse would automatically upgrade itself, so that the new plugin would be installed on his installation. It didn't.
He then tried "Help/Perform Setup tasks", and it didn't installed the plugin neither.
So what's wrong ? Did I misunderstand oomph behaviour ? Did I miss something ?
Thank you.
dom
Re: Update an already eclipse installed through oomph [message #1745312 is a reply to message #1745272] |
Fri, 07 October 2016 08:34   |
Comments inline below.
Dominique Jean-Prost wrote on Fri, 07 October 2016 03:51Hello,
How did you send it, as an attachment and then he copied it somewhere and used it? What kind of setup? A project setup?Quote:
Did he put it where it exactly replaced the setup he's currently using?Quote:
Thank you.
dom
Generally the best way to share it to maintain the setup on a website somewhere and have people point directly as that setup with a URL. Then you can change what's at that URL and everyone will see the changes. But I don't know how you guys exchanged setup, and more specifically where he put his the first time and where he put it the second time.
Re: Update an already eclipse installed through oomph [message #1745368 is a reply to message #1745331] |
Sat, 08 October 2016 14:01  |
The same (folder) location is not sufficient. You must also use the same file name.
In Eclipse, you can open the setup file actually used (Navigate->Open Setup-><theProject>), or you double check the list of tasks you see when manually triggering an update (Help->Perform Setup Task). Check there, whether your changes are actually present.
Alex
FUDForum. Page generated in 0.04656 seconds
