Home » Language IDEs » C / C++ IDE (CDT) » debugger GUI equivalent to GDB 's' (step into) command ?(how to step into a function in CDT debugger)
debugger GUI equivalent to GDB 's' (step into) command ? [message #1744118] Thu, 22 September 2016 09:19 Go to next message
Good day - I am an experienced C & C++ programmer new to eclipse, and I'm simply
trying to step into a function in the current C/C++ project in a version of eclipse CDT .
The debugger is running and the current line is highlighted, displaying eg. :
line#: --> " a_function() ; " <---
How do I get the debugger GUI to issue the gdb 's' command at this point ?
ie I want to single-step to the first C statement in 'a_function()' .
Unfortunately, I cannot run GDB except in the eclipse CDT GUI, I am debugging
code running on hardware connected via JTAG to a proprietary & modified
build of eclipse CDT , which is the only way to debug code running in that device.
Ideally, I'd like to display the machine registers, selected variable values,
and single-step "C"-line by "C"-line through the code the way GDB does -
NOT step into each machine code instruction.
It is very far from clear how to achieve this in the eclipse CDT GUI, and searching
the help was of no use either . I suspect it must be possible with the CDT GUI -
there is probably some obscure graphical squiggle I must click on or an unadvertised
keystroke I must press.
Would anyone be able to enlighten me what the magic keystroke or icon is in CDT
to step into a function with the debugger please ?
Thanks, Jason
Re: debugger GUI equivalent to GDB 's' (step into) command ? [message #1744128 is a reply to message #1744118] Thu, 22 September 2016 10:29 Go to previous messageGo to next message
It's the rigt-angled downward pointing arrow in the Debug View third from right in this image
index.php/fa/27170/0/
It's also in the tool bar and in the Run menu when in the Debug Perspective.
And can be accessed with F5
Here's the help:
http://help.eclipse.org/neon/index.jsp?topic=%2Forg.eclipse.jdt.doc.user%2Freference%2Fviews%2Fdebug%2Fref-stepinto.htm
Found it by googling "eclipse debug step into"
[Updated on: Thu, 22 September 2016 10:39] by Moderator
Re: debugger GUI equivalent to GDB 's' (step into) command ? [message #1744198 is a reply to message #1744128] Fri, 23 September 2016 06:15 Go to previous messageGo to next message
No Message Body
Re: debugger GUI equivalent to GDB 's' (step into) command ? [message #1744199 is a reply to message #1744198] Fri, 23 September 2016 06:16 Go to previous messageGo to next message
No Message Body
Re: debugger GUI equivalent to GDB 's' (step into) command ? [message #1744200 is a reply to message #1744118] Fri, 23 September 2016 06:18 Go to previous messageGo to next message
Thanks! found it. It would be nice to have some reference to & explanation of this graphical squiggle in the online help ...
Re: debugger GUI equivalent to GDB 's' (step into) command ? [message #1744214 is a reply to message #1744200] Fri, 23 September 2016 07:53 Go to previous message
What I linked is the online help.
In what way was it uninformative?
If you meant local help try Help --> Help Contents.
The same help as online will popup in a new window.
You can also search it.
Previous Topic:how to display list of commands run by 'Build All' and save output to a file?
Next Topic:Canceling a build -> every next build will have an error.
Current Time: Sun Jul 20 19:40:40 EDT 2025
Powered by FUDForum. Page generated in 0.02639 seconds
