Home » Eclipse Projects » EclipseLink » Forcing a different operations order on persited entity
Forcing a different operations order on persited entity [message #1742949] Thu, 08 September 2016 14:56 Go to next message
I have an already persisted entity with EclipseLink. I perform some changes on it that cause a constraint violation because of the inserting before updating.
As stated in the documentation the operations are performed in the following order Insert/Update/Delete. There is a method that permits for the delete to be executed first but I can't find any solution to make an update execute before insert. Is there some workaround so I could maybe redefine the order like Delete/Update/Insert?
Re: Forcing a different operations order on persited entity [message #1743797 is a reply to message #1742949] Mon, 19 September 2016 12:27 Go to previous message
Why would inserting before the update cause a constraint violation? Generally something has to exist in the database before any existing rows can be updated to reference them, so the insert/update order is one that is calculated on an entity by entity basis. If there is a constraint being hit, is it something that you have mapped in your entity, or is it due to a circular mapping?
Previous Topic:Exception Description: No conversion value provided for the value
Next Topic:JPA - orphanRemoval in embedded entity not working
Current Time: Sat Jul 19 23:27:29 EDT 2025
Powered by FUDForum. Page generated in 0.04484 seconds
