Home » Eclipse Projects » Equinox » Problem loading plugin with other plugin in Eclipse Application execution
Problem loading plugin with other plugin in Eclipse Application execution [message #1743112] Mon, 12 September 2016 06:47 Go to next message
I've this problem with execution (Run As --> Eclipse Application) of my program (that uses some of my Eclipse plugins).
[ua-shared-pool-0] ERROR org.eclipse.milo.opcua.stack.client.handlers.UaTcpClientMessageHandler - Error decoding OpenSecureChannelResponse: no decoder registered for encodingId=NodeId{ns=0, id=449}
org.eclipse.milo.opcua.stack.core.UaSerializationException: no decoder registered for encodingId=NodeId{ns=0, id=449}
	at org.eclipse.milo.opcua.stack.core.serialization.DelegateRegistry$Instance.getDecoder(DelegateRegistry.java:210)
	at org.eclipse.milo.opcua.stack.core.serialization.binary.BinaryDecoder.decodeMessage(BinaryDecoder.java:366)
	at org.eclipse.milo.opcua.stack.client.handlers.UaTcpClientMessageHandler.lambda$6(UaTcpClientMessageHandler.java:411)
	at org.eclipse.milo.opcua.stack.core.channel.SerializationQueue.lambda$1(SerializationQueue.java:58)
	at org.eclipse.milo.opcua.stack.core.util.ExecutionQueue$PollAndExecute.run(ExecutionQueue.java:107)
	at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.util.concurrent.ExecutionException: UaException: status=Bad_ConnectionClosed, message=connection closed
	at java.util.concurrent.CompletableFuture.reportGet(Unknown Source)
	at java.util.concurrent.CompletableFuture.get(Unknown Source)
	at org.my.package.communication.opcua.OpcUaClientRunner.createClient(OpcUaClientRunner.java:55)
	at org.my.package.communication.opcua.OpcUaClientRunner.run(OpcUaClientRunner.java:99)
Caused by: UaException: status=Bad_ConnectionClosed, message=connection closed
	at org.eclipse.milo.opcua.stack.client.handlers.UaTcpClientMessageHandler.channelInactive(UaTcpClientMessageHandler.java:160)
	at io.netty.channel.ChannelHandlerInvokerUtil.invokeChannelInactiveNow(ChannelHandlerInvokerUtil.java:56)
	at io.netty.channel.DefaultChannelHandlerInvoker.invokeChannelInactive(DefaultChannelHandlerInvoker.java:93)
	at io.netty.channel.AbstractChannelHandlerContext.invokeChannelInactive(AbstractChannelHandlerContext.java:342)
	at io.netty.channel.AbstractChannelHandlerContext.fireChannelInactive(AbstractChannelHandlerContext.java:124)
	at io.netty.handler.codec.ByteToMessageDecoder.channelInputClosed(ByteToMessageDecoder.java:349)
	at io.netty.handler.codec.ByteToMessageDecoder.channelInactive(ByteToMessageDecoder.java:309)
	at io.netty.handler.codec.ByteToMessageCodec.channelInactive(ByteToMessageCodec.java:118)
	at io.netty.channel.DefaultChannelPipeline.fireChannelInactive(DefaultChannelPipeline.java:1060)
	at io.netty.channel.AbstractChannel$AbstractUnsafe$7.run(AbstractChannel.java:733)
	at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:339)
	at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:356)
	at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:742)
	... 1 more
My context in Eclipse Mars version :
I've a plugin A that is used by a plugin B (A<-B).
I've the plugin B that is used by my main program C (B<-C).
At final : A<-B<-C.
I've execute a first time my program C with "Run as --> Java Application". Everything is working normally Smile
I've execute a second time my program C with "Run as --> Eclipse Application". This is where I get the above error :-s
(note that plugin A are eclipse.milo)
Any ideas ?
Thanks in advance !
Re: Problem loading plugin with other plugin in Eclipse Application execution [message #1743467 is a reply to message #1743112] Thu, 15 September 2016 12:13 Go to previous message
Resolved with last update of Eclipse Milo Smile
Previous Topic:news.eclipse.org is shutting down.
Next Topic:Revert to Previous Configuration list is missing in eclipse
Current Time: Sat Jul 19 16:33:39 EDT 2025
Powered by FUDForum. Page generated in 0.03186 seconds
