Home » Eclipse Projects » Sirius » Element Based Edge Creation Tool
Element Based Edge Creation Tool [message #1737783] Tue, 12 July 2016 16:38 Go to next message
I am new to Sirius. I have looked through all the tutorials, examples and forums posts, but have not been able to solve my problem: Is there any detailed tutorial, that describes step by step how to make the creation tool for element based edges? All the tutorials only look at relation based edges.
What do I do wrong, when I have/do the following:
My model:
- classes: NodeSource, NodeTarget (each with variables: incomingArcs (type Arc), outgoingArcs (type Arc), name (type String))
- class: Arc (with variables: source (type NodeSource), target (type NodeTarget), name (type String) )
Now in detail, how I tried to model with Diagram Description in the Diagram.odesign file the relation:
1) New Diagram Element > Element Based Relation
Label: Arc
Domain Class: Arc
Source: NodeSource
Source Finder Expression: feature:source
Target: NodeTarget
Targe Finder Expression: feature:target
2) New Element Creation > Edge Creation
Edge Mapping: Arc
Begin > Change Context var:container > create Instance diagram.Arc > set source feature:source > set target feature:target
I am thinking, that I will have to set the source's outgoingArcs and the target's incomingArcs to the just created new Arc instance.
I hope, I explained it clear enough. I hope you can help me. Thank you in advance!
Re: Element Based Edge Creation Tool [message #1737799 is a reply to message #1737783] Wed, 13 July 2016 02:31 Go to previous messageGo to next message
Le 12/07/2016 à 22:38, Xi Ng a écrit :
> Hello,
There is a sample of EdgeCreatationTool in the advanced tutorial:
https://wiki.eclipse.org/Sirius/Tutorials/AdvancedTutorial#Edge_Creation_Tool
It is a relation based edge, so the tool just have to set the
corresponding relation between both clicked elements. For the eleemnt
based case, it is sligtly different as you have to create the element
and store it in the model and then you need to set the references
between this element and its "source" and "target".
> My model: - classes: NodeSource, NodeTarget (each with variables:
> Label: Arc
> Domain Class: Arc
> Source: NodeSource
> Target: NodeTarget
Do not forget to put a semantic candidates expression to indicate how to
look for Arc from the semantic element of the diagram. It will improve
performances on big modeles: if the semantic candidates is empty, Sirius
will iterate over all semantic models of the current resource set to
look for Arc elements.
> Edge Mapping: Arc
Here you use feature:source and feature:target, so Sirius will look for
the value of the corresponding EReference on the current context, if
your setValue model operations are children of the createInstance task,
yout Arc has just been created and you are setting the current value
(null) to both references.
In the advanced tutorial, you might have missed that we use
var:source/var:target and not feature:, the var: interpreter allows us
to have access to variable set by Sirius, for the edge creation tool,
source and target correspond to the clicked semantic elements.
I think you just have to replace feature: by var: in your tool
Are the source/outgoingArcs and target/incomingArcs set as eOpposite
EReferences in your metamodel ? If yes, EMF will do it for you.
> in advance!
Maxime - Obeo
Re: Element Based Edge Creation Tool [message #1742868 is a reply to message #1737799] Thu, 08 September 2016 06:14 Go to previous messageGo to next message
Hello Maxime,
thank you very much for your help. I appreciate it. I have tried to implement your advice. But I am still struggling. I replaced feature: with var: so far and I have tried out various other things. But I can't solve the problem.
I attached the relevant part of my "net.ecore_diagram" and the relevant parts of my "net.odesign" file.
1. Is this what I modelled eOpposite EReferences, e.g. the two arrows from each Arc to each Element?
2. Is there a good overview, what exactly to write in the "semantic candidates expression"?
3. What do you mean exactly by "you need to set the references between this element and its "source" and "target""?
Thank you in advance.
Kind regards
Xing
[Updated on: Wed, 14 September 2016 01:07] by Moderator
Re: Element Based Edge Creation Tool [message #1742982 is a reply to message #1742868] Fri, 09 September 2016 00:06 Go to previous messageGo to next message
sorry, attachement 02_net_odesign.jpg is wrong.
Please find attached the correct file.
Xing
Re: Element Based Edge Creation Tool [message #1743287 is a reply to message #1742982] Wed, 14 September 2016 01:06 Go to previous messageGo to next message
I have fixed the problem, I edited "Change Context" to [source.eContainer()/]
eOpposites are set.
Kind regards
[Updated on: Sat, 17 September 2016 04:33] by Moderator
Re: Element Based Edge Creation Tool [message #1826744 is a reply to message #1743287] Wed, 29 April 2020 15:11 Go to previous messageGo to next message
Hi Xing,
I am having the same problem that you did here. Can you tell me what you edited in the context or how you did it?
Thomas
Re: Element Based Edge Creation Tool [message #1826769 is a reply to message #1826744] Thu, 30 April 2020 04:46 Go to previous messageGo to next message
I am not sure that Xing will reply...as this post is four years old :) . Have you followed the recommandations in Maxime's answer?
If you still have an issue, can you present how you created your Edge mapping and Edge creation tool?
Steve
Re: Element Based Edge Creation Tool [message #1826826 is a reply to message #1826769] Fri, 01 May 2020 12:28 Go to previous messageGo to next message
Hi Steve,
Attached is my metamodel that I am using.
This is how I set up my edges in sirius:
index.php/fa/38018/0/
And this is how I'm trying to set up the edge creation tool in my editor. I've tried everything that was previously mentioned in this post too.
index.php/fa/38019/0/
Any ideas?
Thomas
[Updated on: Fri, 01 May 2020 12:30] by Moderator
Re: Element Based Edge Creation Tool [message #1833018 is a reply to message #1826769] Wed, 30 September 2020 12:54 Go to previous message
Hi Steve,
Since my last message I have tried to avoid using element based edges as much as possible however it seems there is no avoiding it. Would it be possible to have a step by step tutorial on how to create an element-based edge tool? I have one set up in my new editor that works just fine with the tree editor but I can't get the tool creation to work no matter what configuration I do. Any help would be greatly appreciated.
Previous Topic:References not showing from horizontal stack containers
Next Topic:Reconnect Edge Tool - What is the Variable for "the previous target"?
Current Time: Sun Jul 20 12:57:47 EDT 2025
Powered by FUDForum. Page generated in 0.03572 seconds
