Home » Modeling » TMF (Xtext) » Xtend Template Expressions using ' at the end of '''
Xtend Template Expressions using ' at the end of ''' [message #1742103] Wed, 31 August 2016 08:37 Go to next message
we have some Extension-Methods like
def buildAName(p1, p2, p3) {
    '''p1.p2_p3'''
Some of these methods have to return a value encapsuled in '<value>' (single quote).
So... that is not valid in xtend.
    ''''p1.p2_p3''''
The ' at the end makes an compiler error.
This helps, but... not so beautiful in the output.
    ''''p1.p2_p3' '''
Is there a possibility to "mask" the second ' at the end or something like that?
Thank you for your support,
Tobias
Re: Xtend Template Expressions using ' at the end of ''' [message #1742104 is a reply to message #1742103] Wed, 31 August 2016 08:56 Go to previous messageGo to next message
You could write an extension method that puts the result string in single quotes:
	def buildAName(String p1, String p2, String p3) {
		'''«p1».«p2»_«p3»'''.quote
	def quote (CharSequence s) {
		"'"+s+"'"
Re: Xtend Template Expressions using ' at the end of ''' [message #1742105 is a reply to message #1742103] Wed, 31 August 2016 08:58 Go to previous messageGo to next message
simply escaping does not work?
    	return '''\'p1 p2 p3\'''
Re: Xtend Template Expressions using ' at the end of ''' [message #1742224 is a reply to message #1742105] Wed, 31 August 2016 17:02 Go to previous messageGo to next message
That not works.
class Main {
	def static void main(String[] args) {
		val x = '''\'blabla\'''
		println('''"«x»"''')
will procude the output
"\'blabla\"
Re: Xtend Template Expressions using ' at the end of ''' [message #1742225 is a reply to message #1742104] Wed, 31 August 2016 17:05 Go to previous messageGo to next message
I know the with the quotation in an extension method, but it's not so sexy as the Template Expression Language Wink
... but that is the only solution that i can imagine.
Thank you!
Re: Xtend Template Expressions using ' at the end of ''' [message #1742236 is a reply to message #1742225] Thu, 01 September 2016 00:56 Go to previous message
Can you open a ticket for that
Previous Topic:news.eclipse.org is shutting down.
Next Topic:Indenting multiline values on serialization
Current Time: Sun Jul 20 12:19:34 EDT 2025
Powered by FUDForum. Page generated in 0.07803 seconds
