Home » Eclipse Projects » Oomph » Self contained multi-plaform workspace in USB key
Self contained multi-plaform workspace in USB key [message #1739494] Tue, 02 August 2016 08:46 Go to next message
I would like to know if it is possible with Oomph to setup a workspace and its Eclipse for a specific project from catalog on a USB stick and have this installation usable from different OS.
I.e. a self contained Eclipse without use of centralized bundle pool, with a delta pack to works with all OS.
Best Regards.
Re: Self contained multi-plaform workspace in USB key [message #1739799 is a reply to message #1739494] Tue, 02 August 2016 09:31 Go to previous messageGo to next message
Estaban,
Comments below.
On 02.08.2016 15:13, Esteban Dugueperoux wrote:
> Hi
You mean like Mac, Linux, and Windows? No, an installation can only
work on one type of operating system.
Yes, you can install without a bundle pool so that the installation is
self contained and supports roaming. But a workspace might well not
support roaming. E.g., if it references a git clone, it's likely to do
so with the absolute path of the clone's location.
> Best Regards.
Re: Self contained multi-plaform workspace in USB key [message #1740870 is a reply to message #1739799] Fri, 19 August 2016 05:08 Go to previous messageGo to next message
Hi Ed,
How can I setup an install withou a shared bundle pool?
I haven't seen a such option when using the installer UI.
Best Regards.
Re: Self contained multi-plaform workspace in USB key [message #1740886 is a reply to message #1740870] Fri, 19 August 2016 07:28 Go to previous messageGo to next message
There's an on/off switch next to Bundle Pools... in the simple installer's menu and a check box in the advanced installer.
Re: Self contained multi-plaform workspace in USB key [message #1742053 is a reply to message #1740870] Fri, 19 August 2016 12:59 Go to previous message
Am 19.08.2016 um 11:08 schrieb Esteban Dugueperoux:
> Hi Ed,
>> Yes, you can install without a bundle pool so that the installation is self contained and supports roaming. But a
>> workspace might well not support roaming. E.g., if it references a git clone, it's likely to do so with the absolute
In simple mode there's a switch in the main menu. In advanced mode there's a checkbox at the bottom of the Product page.
Cheers
/Eike
http://www.esc-net.de
Previous Topic:Zipped product archives for Windows
Next Topic:Debugging a task [Solved]
Current Time: Sun Jul 20 03:25:58 EDT 2025
Powered by FUDForum. Page generated in 0.06175 seconds
