Reference online .setup file with authentication [message #1576617] |
Wed, 21 January 2015 07:16  |
we want to reference in the second step our .setup file located on a web server.
This server is protected using BasicAuthentication, which causes a problem.
We are not able to reference it, only in the case if it is downloaded to the local machine.
How can we reference the online protected .setup file directly?
Daniel
Re: Reference online .setup file with authentication [message #1742052 is a reply to message #1740809] |
Thu, 18 August 2016 12:48   |
Peter,
Didn't I answer this like this last time? Where are you accessing
this? Have you tried this trace flag with the installer or IDE (and of
course redirecting stdout to a file so you can review it)?
There is logic in ECFURIHandlerImpl for authorization:
if (authorizatonHandler != null)
if (errorCode == HttpURLConnection.HTTP_UNAUTHORIZED ||
API_GITHUB_HOST.equals(getHost(uri)) && errorCode ==
HttpURLConnection.HTTP_NOT_FOUND)
if (authorization == null)
authorization = authorizatonHandler.authorize(uri);
if (authorization.isAuthorized())
--i;
continue;
You're not being prompted for a user name and password? That's what I
would expect. I have used this with setups that require
authentication, but I think it depends a bit on what kind of
authentication the server requires.
There's also -Doomph.setup.ecf.trace=true which you could try to find
out more what's going on. It prints to stdout...
On 16.08.2016 16:14, Peter Luthardt wrote:
> Hello,
> I am an OOMPH beginner and I got stuck. I have create some project
> setups which I add to the user project by providing there url.
> If I use a url which does not require authentication everything works
> fine, but now we have switched to a secure nexus and the setups are
> not accessible any more.
> I get this exception in the log when trying to access the file directly:
> Caused by: java.io.IOException: Server returned HTTP response code:
> 401 for URL:
> https://depvnx01/nexus/service/local/repositories/snapshots/content/...
> at
> sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1840)
> at
> sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1441)
> at
> sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:254)
> at
> org.eclipse.ecf.provider.filetransfer.retrieve.UrlConnectionRetrieveFileTransfer.getDecompressedStream(UrlConnectionRetrieveFileTransfer.java:552)
> at
> org.eclipse.ecf.provider.filetransfer.retrieve.UrlConnectionRetrieveFileTransfer.openStreams(UrlConnectionRetrieveFileTransfer.java:322)
> ... 49 more When I use the redirection url
> (https://depvnx01/nexus/service/local/artifact/maven/redirect?r=public&g=...&a=..&v=LATEST&e=setup)I
> get no exception and nothing happens.
> The best way would be to access the setup from our svn server, but
> here I need authentication, too
> Could you please give me a hint where to look. Or do I use the wrong
> approach?
> Thanks.
On 18.08.2016 18:26, Peter Luthardt wrote:
> Hope I am not out of topic,
> I want to access my project.setup from our svn with a url like:
> https://157.163.26.183:8443/!/#TNT/view/head/TNT/trunk/tnt/tnt-oomphsetup/TNTSecureNexus.setup
> But nothing happens. I do not see anything in the log, and no popup
> appears!
Re: Reference online .setup file with authentication [message #1752967 is a reply to message #1752961] |
Tue, 31 January 2017 07:21  |
Hi Ed, thanks for the quick reply but it's not that urgent.
I had a look into the ECFURIHandlerImpl and it was just too complex to get to the point quickly enougth.
However, I'll setup a small test repo on our gitlab server for you and will contact you through mail. Maybe you have some time for it after your travelling.
Thanks so far!
FUDForum. Page generated in 0.11816 seconds
