Home » Archived » BIRT » Eclipse Freeze while editing Birt report parameter (having long sql query) in .rptdesign file's rept(Birt Report Issue)
Eclipse Freeze while editing Birt report parameter (having long sql query) in .rptdesign file's rept [message #1741833] Tue, 30 August 2016 00:14
Eclipse [Bug 498491] :
System Configuration:
Ubuntu - Linux Mint 18 sarah
Eclipse - Eclipse IDE for Java and Report Developers
Version: Mars.2 Release (4.5.2)
Build id: 20160218-0600
Java-8
Report Type - Birt Report.
I tried with GTK2 by adding in eclipse.ini
--launcher.GTK_version
2
--launcher.appendVmargs
-vmargs
Earlier I war using Eclipse Mars on Windows plateform, there everything was working fine. But 2 Days back our IT Administrator has installed Linux Mint 18 sarah on my system.
Now, I am trying to edit one Birt Report (e.g. projectList.rptdesign file). Data Source Test connection is successful. DataSet is showing all the columns/fields.
Actual Query: Different cases, all making eclipse mars freeze (I need to forfully quit only). In Report Parameters, I have query Parameter
case1: I right click or double click on report Parameter, eclipse gets freeze because this parameter is having large sql Query parameter (say around 2000 words)
case 2: I create a new parameter, I try to copy that long sql query, eclipse gets freeze.
My Understanding: It takes time to read from or write sql query to .rptdesign file. After long time (sometimes in 10 min, 20 minutes) eclipse becomes fine, after writing or reading the sql query to rptdesign file. It look this is plugin issue.
Note: This issue occurs, even without start tomcat server as well as after starting tomcat server.
Previous Topic:Install not working on tomcat
Next Topic:news.eclipse.org is shutting down.
Current Time: Sat Jul 19 13:12:14 EDT 2025
Powered by FUDForum. Page generated in 0.04498 seconds
