[EMFForms]Trouble with Table Control domain model reference [message #1741164] |
Tue, 23 August 2016 08:38  |
I'm new to EMFForms and ECP so forgive me if i'm doing something obviously wrong. I'm trying to create a table control but having difficulty setting the domain reference in the wizard. When I click the button to set the domain reference, I select table domain reference and select next. I am then presented with the same wizard and am not given the chance to select the property in my ecore model.
I have set the property type for the containment reference in the GenModel to editable per the instructions in the getting started guide.
I have a fresh download of Eclipse Neon with ECP SDK version 1.9.0.20160606-1526
Thanks in advance for your assistance.
Bill
Re: [EMFForms]Trouble with Table Control domain model reference [message #1741674 is a reply to message #1741173] |
Fri, 26 August 2016 22:36   |
Thanks Eugen, that helps a bit until I attempt to add columns, it looks like the column specifications fail EMFForms validation with the following error reported for each column: "Domain model reference is unresolvable. Failed on domain model Feature: myFieldName"
This happens when I use the generate columns feature in the control browser in the editor and when I attempt to do it manually.
When I run the app, the columns appear, but I do get an additional column titled Validation Status. Is there any way to prevent that from getting added?
I'm probably overloading this thread, but I have two other things I'm seeing which are puzzling.
First, when I open an element for editing, it appears that the width of the tabbed panel is only slightly wider that the tab title which causes the controls to be rendered in a very narrow space. When I edit a property and move to edit another, the panel resizes and consumes the full editing pane as it is supposed to.
Second, I'm seeing different behavior when I run the app as an e4 product vs an e3 product. When running as e4, I don't get the option to add repositories and when I attempt to connect to the local server I get an exception stating the workbench has not yet been created. I also do not see the narrow controls as I describe in the previous paragraph.
Perhaps these topics deserve their own thread?
FUDForum. Page generated in 0.04388 seconds
