Home » Modeling » TMF (Xtext) » xText: Maven no class def found error
xText: Maven no class def found error [message #1741268] Wed, 24 August 2016 05:39 Go to next message
Hello community
if create the greeting example with a maven build. I get always (windows) follow error:
1    [org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main()] ERROR mf.mwe2.launch.runtime.Mwe2Launcher  - org/eclipse/emf/ecore/resource/Resource$Factory$Registry
java.lang.NoClassDefFoundError: org/eclipse/emf/ecore/resource/Resource$Factory$Registry
	at org.eclipse.emf.mwe2.language.Mwe2StandaloneSetupGenerated.createInjectorAndDoEMFRegistration(Mwe2StandaloneSetupGenerated.java:21)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:75)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
	at org.codehaus.mojo.exec.ExecJavaMojo$1.run(ExecJavaMojo.java:293)
	at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.ClassNotFoundException: org.eclipse.emf.ecore.resource.Resource$Factory$Registry
	at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
	... 9 more
Which maven dependencies must be added?
Re: xText: Maven no class def found error [message #1741272 is a reply to message #1741268] Wed, 24 August 2016 06:04 Go to previous messageGo to next message
Which Xtext version do you use?
Re: xText: Maven no class def found error [message #1741279 is a reply to message #1741272] Wed, 24 August 2016 06:25 Go to previous messageGo to next message
<xtextVersion>2.10.0</xtextVersion>
Re: xText: Maven no class def found error [message #1741284 is a reply to message #1741279] Wed, 24 August 2016 06:52 Go to previous messageGo to next message
hmmm maybe your m2/repository dir contains some wrong stuff.
just booted by windows and it is working fine
Re: xText: Maven no class def found error [message #1741376 is a reply to message #1741284] Wed, 24 August 2016 10:09 Go to previous message
Thanks for the hint with the maven repo. I deleted my maven repo and start it again, works Smile . Maye a corrupt jar by a broken download.
Previous Topic:use of ->
Next Topic:Algorithmic language project for writing algorithms in French.
Current Time: Sat Jul 19 21:02:59 EDT 2025
Powered by FUDForum. Page generated in 0.26501 seconds
