Home » Eclipse Projects » Eclipse Platform » Cannot run Eclipse(Error when run eclipse Neon)
Cannot run Eclipse [message #1736529] Thu, 30 June 2016 04:34 Go to next message
Hello, my name is Antonio.
I have installed Eclipse Neon and i install jboss tools 4.4.0 and vaadin from eclipse market.
When eclipse has finished, i restart and show next error and cannot run eclipse:
!SESSION 2016-06-30 09:18:51.760 -----------------------------------------------
eclipse.buildId=4.6.0.I20160606-1100
java.version=1.8.0_92
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=es_ES
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.equinox.ds 2 0 2016-06-30 09:19:27.035
!MESSAGE [SCR - WorkThread] Timeout occurred! Thread was blocked on processing [QueuedJob] WorkPerformer: org.eclipse.equinox.internal.ds.SCRManager@1b80af60; actionType 1
!ENTRY org.eclipse.equinox.ds 2 0 2016-06-30 09:19:27.049
!MESSAGE [SCR] Enabling components of bundle org.eclipse.ui.trace did not complete in 30000 ms
!ENTRY org.eclipse.core.runtime 4 0 2016-06-30 09:19:32.084
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Unable to acquire the state change lock for the module: osgi.identity; type="osgi.bundle"; version:Version="3.12.0.v20160606-1342"; osgi.identity="org.eclipse.core.runtime"; singleton:="true" [id=113] STARTED [STARTED]
at org.eclipse.osgi.container.Module.lockStateChange(Module.java:337)
at org.eclipse.osgi.container.Module.start(Module.java:401)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.util.concurrent.TimeoutException: Timeout after waiting 5 seconds to acquire the lock.
at org.eclipse.osgi.container.Module.lockStateChange(Module.java:334)
... 8 more
Root exception:
!ENTRY org.eclipse.osgi 2 0 2016-06-30 09:19:37.685
!MESSAGE While loading class "org.eclipse.oomph.p2.internal.core.P2CorePlugin$Implementation", thread "Thread[Start Level: Equinox Container: 907603e7-923e-0016-1970-89fcf9cec02f,5,main]" timed out waiting (5002ms) for thread "Thread[Component Resolve Thread,5,main]" to finish starting bundle "org.eclipse.core.runtime_3.12.0.v20160606-1342 [113]". To avoid deadlock, thread "Thread[Start Level: Equinox Container: 907603e7-923e-0016-1970-89fcf9cec02f,5,main]" is proceeding but "org.eclipse.oomph.p2.internal.core.P2CorePlugin$Implementation" may not be fully initialized.
!STACK 0
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:470)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:325)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:334)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:411)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:361)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:353)
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:757)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:711)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:932)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.createInstance(ServiceComponent.java:493)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.createInstance(ServiceComponentProp.java:270)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:331)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.ServiceReg.getService(ServiceReg.java:53)
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212)
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210)
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111)
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:496)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461)
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:619)
at org.eclipse.equinox.internal.p2.core.Activator.registerAgent(Activator.java:175)
at org.eclipse.equinox.internal.p2.core.Activator.start(Activator.java:244)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:774)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:767)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:724)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:395)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:758)
... 78 more
Root exception:
!ENTRY org.eclipse.osgi 2 0 2016-06-30 09:19:42.687
!MESSAGE While loading class "org.eclipse.oomph.p2.internal.core.P2CorePlugin$Implementation", thread "Thread[Start Level: Equinox Container: 907603e7-923e-0016-1970-89fcf9cec02f,5,main]" timed out waiting (5000ms) for thread "Thread[Component Resolve Thread,5,main]" to finish starting bundle "org.eclipse.equinox.registry_3.6.100.v20160223-2218 [363]". To avoid deadlock, thread "Thread[Start Level: Equinox Container: 907603e7-923e-0016-1970-89fcf9cec02f,5,main]" is proceeding but "org.eclipse.oomph.p2.internal.core.P2CorePlugin$Implementation" may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: Unable to acquire the state change lock for the module: osgi.identity; type="osgi.bundle"; version:Version="3.6.100.v20160223-2218"; osgi.identity="org.eclipse.equinox.registry"; singleton:="true" [id=363] STARTED [STARTED]
... 78 more
Root exception:
!ENTRY org.eclipse.osgi 2 0 2016-06-30 09:19:47.729
!MESSAGE While loading class "org.eclipse.core.runtime.Platform", thread "Thread[Start Level: Equinox Container: 907603e7-923e-0016-1970-89fcf9cec02f,5,main]" timed out waiting (5001ms) for thread "Thread[Component Resolve Thread,5,main]" to finish starting bundle "org.eclipse.core.runtime_3.12.0.v20160606-1342 [113]". To avoid deadlock, thread "Thread[Start Level: Equinox Container: 907603e7-923e-0016-1970-89fcf9cec02f,5,main]" is proceeding but "org.eclipse.core.runtime.Platform" may not be fully initialized.
!STACK 0
at org.eclipse.osgi.internal.loader.sources.MultiSourcePackage.loadClass(MultiSourcePackage.java:32)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:407)
at org.eclipse.emf.common.EMFPlugin.<clinit>(EMFPlugin.java:65)
at org.eclipse.emf.common.CommonPlugin$Implementation.<init>(CommonPlugin.java:162)
at org.eclipse.emf.common.CommonPlugin$Implementation$Activator.createBundle(CommonPlugin.java:267)
at org.eclipse.emf.common.EMFPlugin$OSGiDelegatingBundleActivator.createBundleHelper(EMFPlugin.java:187)
at org.eclipse.emf.common.EMFPlugin$OSGiDelegatingBundleActivator.<init>(EMFPlugin.java:180)
at org.eclipse.emf.common.CommonPlugin$Implementation$Activator.<init>(CommonPlugin.java:262)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
... 107 more
Root exception:
!ENTRY org.eclipse.osgi 2 0 2016-06-30 09:19:52.735
!MESSAGE While loading class "org.eclipse.core.internal.runtime.Messages", thread "Thread[Start Level: Equinox Container: 907603e7-923e-0016-1970-89fcf9cec02f,5,main]" timed out waiting (5000ms) for thread "Thread[Component Resolve Thread,5,main]" to finish starting bundle "org.eclipse.core.runtime_3.12.0.v20160606-1342 [113]". To avoid deadlock, thread "Thread[Start Level: Equinox Container: 907603e7-923e-0016-1970-89fcf9cec02f,5,main]" is proceeding but "org.eclipse.core.internal.runtime.Messages" may not be fully initialized.
!STACK 0
at org.eclipse.core.runtime.Platform.<clinit>(Platform.java:434)
at org.ec
Re: Cannot run Eclipse [message #1741013 is a reply to message #1736529] Mon, 22 August 2016 07:29 Go to previous message
Does it work if you install only JBoss Tools or only Vaadin?
Previous Topic:create custom folder structure
Next Topic:Overriding standard commands
Current Time: Sun Jul 20 18:44:08 EDT 2025
Powered by FUDForum. Page generated in 0.08283 seconds
