Home » Modeling » Compare » Undo Redo Functionality Not working in EMF Compare in Dialog(Undo Redo Functionality Not working in EMF Compare in Dialog)
Undo Redo Functionality Not working in EMF Compare in Dialog [message #1739585] Wed, 03 August 2016 03:10 Go to next message
I am comparing two model using EMF Compare in Dialog and not Editor. After doing one or more merging from right to left when I do ctrl+z it's not working.
May I know the reason why it's not working ?
Any help is appreciated.
Thanks in advance.
Re: Undo Redo Functionality Not working in EMF Compare in Dialog [message #1740610 is a reply to message #1739585] Tue, 16 August 2016 04:15 Go to previous messageGo to next message
Do you have anything in the error log when trying to reproduce this?
Laurent Goubet
Obeo
Re: Undo Redo Functionality Not working in EMF Compare in Dialog [message #1740977 is a reply to message #1740610] Mon, 22 August 2016 01:07 Go to previous messageGo to next message
Hi Laurent,
It's not showing any error in error log.
But when I am trying to print the value of getCommandStack().canUndo(), it is printing false.
Thanks.
Re: Undo Redo Functionality Not working in EMF Compare in Dialog [message #1741490 is a reply to message #1740977] Thu, 25 August 2016 10:04 Go to previous messageGo to next message
The undo action is never called from the dialog, but I have no idea why since it's properly created and made enabled. Could you raise this issue on the bugzilla?
Laurent Goubet
Obeo
Re: Undo Redo Functionality Not working in EMF Compare in Dialog [message #1743324 is a reply to message #1741490] Wed, 14 September 2016 07:47 Go to previous messageGo to next message
Hi Laurent,
It's already raised.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=480400
It's not fixed yet.
Gaurav
Re: Undo Redo Functionality Not working in EMF Compare in Dialog [message #1743711 is a reply to message #1743324] Mon, 19 September 2016 03:45 Go to previous message
Hi, and sorry, didn't find that with a quick search so I guess I was using wrong filters.
It is not fixed yet because the compare dialog isn't a priority of us for now. We'll gladly welcome contributions if you're willing to try and fix this issue, but investigations are not planned on our side to get this to work.
Laurent Goubet
Obeo
Previous Topic:EMF Compare 3.2 compatibility
Next Topic:Elements matching order
Current Time: Sun Jul 20 04:39:30 EDT 2025
Powered by FUDForum. Page generated in 0.04384 seconds
