Home » Language IDEs » Java Development Tools (JDT) » Error Updating Eclipse Mars From Java 1.7 to 1.8
Error Updating Eclipse Mars From Java 1.7 to 1.8 [message #1740845] Thu, 18 August 2016 18:29 Go to next message
I have recently tried to update java from 1.7 to 1.8 in eclipse mars 2.0.
I installed the Java SE Runtime Environment 8 for mac
However, when I got to preferences<Java<Installed JRE's<Add<Standard VM<Directory and then select the folder I get this error at the top of the popup: Target is not a JDK Root. Java executable was not found
I would really appreciate your help. Thanks.
Re: Error Updating Eclipse Mars From Java 1.7 to 1.8 [message #1740895 is a reply to message #1740845] Fri, 19 August 2016 11:13 Go to previous messageGo to next message
You probably gave it the parent (or perhaps a child) of the folder it needs. Try going one folder deeper, and/or one folder up.
Re: Error Updating Eclipse Mars From Java 1.7 to 1.8 [message #1740899 is a reply to message #1740845] Fri, 19 August 2016 11:13 Go to previous message
Previous Topic:Eclipse problem with JavaFX
Next Topic:Configure local server operations to actually rebuild the war file via mvn clean?
Current Time: Sun Jul 20 08:00:17 EDT 2025
Powered by FUDForum. Page generated in 0.03571 seconds
