Home » Eclipse Projects » JFace » [HiDPI icons] How to migrate from ImageDescriptor#createFromFile to #createFromURL?
[HiDPI icons] How to migrate from ImageDescriptor#createFromFile to #createFromURL? [message #1740762] Thu, 18 August 2016 06:41 Go to next message
I want to make use of the HiDPI icon support added in Neon. Now, my code creates ImageDescriptors using ImageDescriptor#createFromFile(Class, URL) rather than ImageDescriptor#createFromURL(URL). Unfortunately, the former method does not search for available HiDPI icons; only the latter does (as documented in the Neon release notes).
Hence, I have to migrate from createFromFile(Class, URL) to createFromURL(URL), but am at a loss as to how to convert my Class + URL to an absolute URL of the form bundleentry://.../path apprently required by ImageDescriptor#createFromURL(URL).
Any pointers on how to do this migration are hence greatly appreciated.
Andreas
Re: [HiDPI icons] How to migrate from ImageDescriptor#createFromFile to #createFromURL? [message #1740766 is a reply to message #1740762] Thu, 18 August 2016 07:27 Go to previous messageGo to next message
Made some progress using org.osgi.framework.FrameworkUtil#getBundle(Class) and org.eclipse.ui.internal.util.BundleUtility#find(Bundle, String). The latter is unfortunately marked as internal. If someone has an idea how to avoid BundleUtility, I'd like to hear it.
Re: [HiDPI icons] How to migrate from ImageDescriptor#createFromFile to #createFromURL? [message #1740777 is a reply to message #1740762] Thu, 18 August 2016 09:26 Go to previous messageGo to next message
I think you must mean ImageDescriptor.createFromFile(Class, String), not URL.
If your class a.b.c.C is in bundle B, and the image name is F, then use:
platform:/plugin/B/a/b/c/F
That's assuming your bundle follows the normal layout, where the classes are laid out from the root of the bundle.
Brian.
Re: [HiDPI icons] How to migrate from ImageDescriptor#createFromFile to #createFromURL? [message #1740778 is a reply to message #1740777] Thu, 18 August 2016 09:39 Go to previous messageGo to next message
Brian de Alwis wrote on Thu, 18 August 2016 09:26
Right. That was a copy-and-paste error.
I was hoping to avoid hard-coding the bundle name (in addition to the path); createFromFile's use of Class instances is very convenient in this respect.
But you are right: platform:/ URIs work, although they are less convenient than using createFromFile.
FWIW, is there any reason why createFromFile doesn't search for @2x images? That ImageDescriptor#createFromURL is the only method that got HiDPI-enabled with Neon seems like an oversight to me.
Re: [HiDPI icons] How to migrate from ImageDescriptor#createFromFile to #createFromURL? [message #1740816 is a reply to message #1740778] Thu, 18 August 2016 13:05 Go to previous messageGo to next message
I don't know why createFromFile() was not updated. Patches welcome, of course Smile
Re: [HiDPI icons] How to migrate from ImageDescriptor#createFromFile to #createFromURL? [message #1740858 is a reply to message #1740816] Fri, 19 August 2016 03:29 Go to previous message
Brian de Alwis wrote on Thu, 18 August 2016 13:05
Of course. Not sure whether I'm familiar enough with the ImageDescriptor code to do this, though.
But I've filled Bug 499964 at least, so this issue doesn't get lost.
Previous Topic:[Databinding/E4] Binding of nested properties
Next Topic:Add Scroller to a long JFace MenuManager
Current Time: Sun Jul 20 18:55:05 EDT 2025
Powered by FUDForum. Page generated in 0.06444 seconds
