Home » Eclipse Projects » Model Driven Health Tools » Support for JDK1.6(Support for JDK1.6 - CDA 2.1 and CDA 1.1 libraries)
Support for JDK1.6 [message #1740186] Wed, 10 August 2016 04:42 Go to next message
We are using JDK1.6 runtime environment, but seems like the latest consol1 and consol2 jars need 1.7 environment. Are there 1.6 compatible libraries?
I am trying to use the following:
https://github.com/mdht/mdht-models/releases/tag/v2.5.16.20160725_Consol2
https://github.com/mdht/mdht-models/releases/tag/v2.5.8.20160323_Consol1
Anand
Re: Support for JDK1.6 [message #1740206 is a reply to message #1740186] Wed, 10 August 2016 08:55 Go to previous messageGo to next message
Is there specific a reason you can not upgrade to 1.7 at least 1.8 preferred ?
It is the easier approach
I do not believe we have any 1.7 or greater specific java code
The method we would follow is to create a profile for the maven build
This would need to be done for both the core and models
Are you familiar with maven ?
Sean
Re: Support for JDK1.6 [message #1740208 is a reply to message #1740206] Wed, 10 August 2016 09:06 Go to previous messageGo to next message
Sean
Due to complexity of our product, we won't be able to upgrade to 1.7 or higher.
I am not familiar with maven as we are using ANT internally.
It would really be helpful if you can provide the 1.6 compatible libraries of the releases I mentioned earlier.
Thanks in advance
Narinder
Re: Support for JDK1.6 [message #1740223 is a reply to message #1740186] Wed, 10 August 2016 10:29 Go to previous message
There is nothing recent avaialable for JDK1.6. If you or someone wanted to spend the time, I don't think it would be too much work to produce though.
Previous Topic:Generating EMF from FHIR artifacts
Next Topic:XSI/Template Processing
Current Time: Sun Jul 20 14:45:07 EDT 2025
Powered by FUDForum. Page generated in 0.23563 seconds
