Home » Archived » Hudson » Git url of repository with parameter
Git url of repository with parameter [message #1739909] Fri, 05 August 2016 11:49 Go to next message
Dear all
I have difficulty to setup our eclipse HIPP to match a git url of repository with a build parameter [1]
I have a build parameter COMPONENT_GIT_NAME
I am trying to inject it in the source code management plugin with git with
URL of repository:
/gitroot/papyrus/org.eclipse.papyrus-$COMPONENT_GIT_NAME.git
or
/gitroot/papyrus/org.eclipse.papyrus-${COMPONENT_GIT_NAME}.git
any idea how to use a build parameter in the url of repository?
[1]: https://hudson.eclipse.org/papyrus/view/Component/job/papyrus-component-deploy-website/
Re: Git url of repository with parameter [message #1740026 is a reply to message #1739909] Mon, 08 August 2016 07:51 Go to previous messageGo to next message
Dear all,
I have also tested ${env.COMPONENT_GITNAME}, it does not work...
Any idea?
Re: Git url of repository with parameter [message #1740063 is a reply to message #1740026] Mon, 08 August 2016 12:24 Go to previous message
Answered here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=499148#c4
BTW: The env-prefix is the default prefix in Ant for environment variables, but not in Hudson.
So ${env.SOMETHING} won't work in a Hudson job configuration field unless you define your parameter with the same prefix.
Previous Topic:Steps to migrate from v2.2.1 to 3.3.2 ?
Next Topic:How to specify different branches for job build using multiple git repositories?
Current Time: Sun Jul 20 14:26:50 EDT 2025
Powered by FUDForum. Page generated in 0.25362 seconds
