Re: Configure perspective with Oomph [message #1738898 is a reply to message #1738882] |
Mon, 25 July 2016 15:38   |
Hi, Ed,
Isn't there an Eclipse Launcher command-line option that can set the
initial perspective, which Oomph can add to the eclipse.ini using an
"Eclipse Ini" task?
-perspective your.perspective.id.here
cW
On 2016-07-25 16:44:58 +0000, Ed Merks said:
> Harald,
> No, we have some prototype work for that, but nothing you can use today.
> On 25.07.2016 18:18, Harald Brunner wrote:
>> Hi,
>> is there a way to configure a perspective within an Oomph setup file?
>> E.g. change the default Plug-In Development perspective, or add a
>> custom perspective.
>> Thanks,
>> Harald
Re: Configure perspective with Oomph [message #1738900 is a reply to message #1738898] |
Mon, 25 July 2016 16:01  |
Christian,
Yes, but that doesn't let you configure an existing perspective. You'd
need to install something that contributes a new per-configured
perspective. Ideally it would be much easier to do than installing
something that contributes to extension points...
On 25.07.2016 21:38, Christian W. Damus wrote:
> Hi, Ed,
> "Eclipse Ini" task?
> cW
>> Harald,
>>> Hi,
>>> custom perspective.
>>> Thanks,
>>> Harald
FUDForum. Page generated in 0.04103 seconds
