Home » Newcomers » Newcomers » Show view does nothing for most views
icon5.gif  Show view does nothing for most views [message #1738684] Fri, 22 July 2016 04:51 Go to next message
I upgraded to Eclipse Neon on linux and now I have a problem with some of my views.
Namely, selecting them from window -> show view does nothing. No new window opens and seemingly nothing happens.
I tried all the default views from the menu. Not working: ant, declaration, error log, javadoc, outline, problems, progress, search, tasks, templates.
The rest of them work as expected, like console and type hierarchy. Opening them from the menu works and if I close them and select them again they open just fine.
What's going on? Is there a log file somewhere I could look at? I started eclipse from an xterm and saw no relevant output to stdout/stderr.
Re: Show view does nothing for most views [message #1738723 is a reply to message #1738684] Fri, 22 July 2016 11:26 Go to previous messageGo to next message
I know on some Linux flavor that GTK 2 works better than GTK 2 so
perhaps it's related to that. Perhaps it's work a try to add the two lines
--launcher.GTK_version
2
before the -vmargs in the eclipse.ini.
There is an Error Log view (which you say doesn't work either) which
shows what's in <workspace>/.metadata/.log.
If you run eclipse with -consoleLog, it should log to the terminal as well.
> of my views.
> tasks, templates.
> stdout/stderr.
Re: Show view does nothing for most views [message #1738809 is a reply to message #1738723] Mon, 25 July 2016 02:11 Go to previous message
I ended up moving my workspace away and starting a fresh one. It works now, I can live with that.
Previous Topic:Eclipse "Installation failed with Error"
Next Topic:ECLIPS NEON ISSUES
Current Time: Sun Jul 20 04:13:16 EDT 2025
Powered by FUDForum. Page generated in 0.08169 seconds
