Home » Eclipse Projects » Equinox » Uninstall an eclipse plugin programmatically
Uninstall an eclipse plugin programmatically [message #1738445] Tue, 19 July 2016 19:12 Go to next message
I'm developing an eclipse plugin that when the user clicks a button, another plugin is uninstalled programmatically.
I tried:
Bundle b1 = Platform.getBundle(bundleId);
b1.uninstall();
The plugin stops to work. However, the graphical elements are not deleted.
Then I tried:
http://stackoverflow.com/questions/9927400/how-do-i-easily-query-a-running-eclipse-for-its-installed-features?rq=1
I could find the corresponding IInstallableUnit
Then I use the following code:
private void scheduleUninstallOperationJob(
	        Collection<? extends IVersionedId> toUninstall)
	    OperationFactory oFactory = new OperationFactory();
	    Collection<URI> repos = null;
	    UninstallOperation op = null;
	    try {
	        op = oFactory.createUninstallOperation(toUninstall, repos, null);
	    } catch (ProvisionException e) {
	        e.printStackTrace();
	    IStatus result = op.resolveModal(null);
	    if (result.isOK()) {
	        op.getProvisioningJob(null).run(null);
In this case, both plugin and UI are not deleted.
Finally, somebody can help me and say how to uninstall or even disable an eclipse plugin programmatically from another plugin.
Thanks in advance.
Re: Uninstall an eclipse plugin programmatically [message #1738509 is a reply to message #1738445] Wed, 20 July 2016 09:09 Go to previous message
Uninstalling a bundle should be all that is needed. If the bundle exports packages then you likely will want to perform a refreshBundles opertation [1]. But it sounds like the e4 UI layer is not recognizing that the bundle with the UI elements is going away. I would ask this on the eclipse e4 forum.
[1] https://osgi.org/javadoc/r6/core/org/osgi/framework/wiring/FrameworkWiring.html#refreshBundles(java.util.Collection,%20org.osgi.framework.FrameworkListener...)
Previous Topic:Missing code signer information for third party JAR
Next Topic:HttpSessionAdapter
Current Time: Sun Jul 20 02:58:51 EDT 2025
Powered by FUDForum. Page generated in 0.04249 seconds
