performSetCommand not using own model ItemProviderAdapter [message #1737678] |
Mon, 11 July 2016 19:18  |
Hi all,
I am trying the new command-related services in Sirius 4.0, especially the performSetCommand(). In the documentation you can read:
Quote:The implementation of these services delegate to the ItemProviderAdapter.createCommand() method, so any customization made in the ItemProviderAdapter 's implementation will be taken into account.
In the corresponding ItemProviderAdapters of my model I have made several customizations, but they are not used when I call for example performSetCommand(). Debugging the Sirius code shows that performSetCommand() indeed is called as expected and a standard SetCommand is performed. But my customizations are not used, since the Sirius EditingDomain (TransActionionalEditingDomainImpl) is not aware of the ItemProviders of my model, since
IEditingDomainItemProvider editingDomainItemProvider =
(IEditingDomainItemProvider)
adapterFactory.adapt(owner, IEditingDomainItemProvider.class); results in editingDomainItemProvider == null (owner is an object of my model).
Did I miss something? Do I have to add my models AdapterFactories to the EditingDomain of Sirius myself? And if so, how can I do it?
Any help would be greatly appreciated.
Re: performSetCommand not using own model ItemProviderAdapter [message #1737703 is a reply to message #1737678] |
Tue, 12 July 2016 03:29   |
Hi Joachim,
Le 12/07/2016 à 01:18, Joachim Anlauf a écrit :
> Hi all,
> Quote:
> IEditingDomainItemProvider.class);results in editingDomainItemProvider
In which context do you try this performSetCommand() ? In a model
operation of a tool ? Is your object alreayd attached to its
parent/resource ?
You should not have to do so: the editing domain is initialized with a
ComposedAdapterFactory aware of the
ComposedAdatperFactory.Descriptor.Registry.INSTANCE, so if you have
properly declared your EMF.edit plugin, it should work.
org.eclipse.sirius.ext.emf.edit.EditingDomainServices.getEditingDomain(EObject)
calls
org.eclipse.emf.edit.domain.AdapterFactoryEditingDomain.getEditingDomainFor(EObject)
which will return true if the object's resoure is null.
But the fact that you have a command shows that the domain is found.
It looks like the ReflectiveItemProviderAdapterFactory has been found
instead of yours.
Could you check your extension to <extension
point="org.eclipse.emf.edit.itemProviderAdapterFactories">, its
supported type, the uri and the class ?
Maxime - Obeo
Re: performSetCommand not using own model ItemProviderAdapter [message #1737767 is a reply to message #1737763] |
Tue, 12 July 2016 12:22  |
Le 12/07/2016 à 17:37, Joachim Anlauf a écrit :
> Hi Maxime,
> many thanks for your quick reply.
> Your last sentence was the key:
> I was not aware of the fact that I have to use this extension point in
> order to register my ItemProviderAdapterFactory. I added it and now my
> performSetCommand() is working as expected. Thanks a lot again.
> One additional question:
>> parent/resource ?
> My object is attached to its container already, therefore it belongs to
> a Resource, before I call performSetCommand(). I call it inside an edge
> creation tool in the Browse Expression of a Change Context node:
My question was in case your extension point had been ok, to identify
where to check the initalization of the tool execution context.
Regards.
Maxime - Obeo
FUDForum. Page generated in 0.03750 seconds
