Home » Eclipse Projects » Oomph » Get current version name for 'latest.released' product
Get current version name for 'latest.released' product [message #1737575] Sun, 10 July 2016 10:17 Go to next message
In the url attribute of a p2 director task, I need to do something like:
http://download.eclipse.org/sirius/updates/releases/4.0./${scope.product.version.name|lower}
This works when the user initially selects 'Mars' or 'Neon', but not for
"Latest (Neon)" or "Latest Released (Neon)". Is there a 'filter' or
variable that always resolves to the current version name?
Asking more generally, how do I install a given feature from a p2 site
whose location depends on the selected product version?
Felix
Re: Get current version name for 'latest.released' product [message #1737576 is a reply to message #1737575] Sun, 10 July 2016 10:55 Go to previous messageGo to next message
Hi Felix,
Comments below...
Cheers
/Eike
http://www.esc-net.de
Am 10.07.2016 um 17:17 schrieb Felix Dorner:
> This works when the user initially selects 'Mars' or 'Neon', but not for "Latest (Neon)" or "Latest Released (Neon)".
> Is there a 'filter' or variable that always resolves to the current version name?
No, there's no such filter or variable available.I guess we could add such variables if you open a bugzilla.
> Asking more generally, how do I install a given feature from a p2 site whose location depends on the selected product
> version?
Generally these features and their transitive contents *should have* adequate version ranges in their dependencies and
generally, if there are multiple p2 repositories with different such sets of IUs, there also *should be* a composite
repo. So, in an ideal world it should all work by itself :P
Re: Get current version name for 'latest.released' product [message #1737603 is a reply to message #1737576] Mon, 11 July 2016 04:05 Go to previous messageGo to next message
Hello Eike,
>> for "Latest (Neon)" or "Latest Released (Neon)". Is there a 'filter'
Ok I'll see.
> adequate version ranges in their dependencies and generally, if there
> *should be* a composite repo. So, in an ideal world it should all work
> by itself :P
You mean that if I add both repositories (or one hypothetical composite
one), if the requested feature had proper version ranges the installer
would automatically use the one that matches? (I would really think
that's the way it should work but... I must see to believe.)
In the case of Sirius it's actually a weird one, since their repos
contain exactly the same code, however the mars repo is built against
mars, and the neon repo is built against neon.
Re: Get current version name for 'latest.released' product [message #1737605 is a reply to message #1737603] Mon, 11 July 2016 04:28 Go to previous message
Am 11.07.2016 um 11:05 schrieb Felix Dorner:
> You mean that if I add both repositories (or one hypothetical composite one), if the requested feature had proper
> version ranges the installer would automatically use the one that matches?
Yes.
Cheers
/Eike
Previous Topic:provision additional projects afterwards
Next Topic:ssh key settings
Current Time: Sat Jul 19 21:07:59 EDT 2025
Powered by FUDForum. Page generated in 0.03701 seconds
