Home » Eclipse Projects » e(fx)clipse » @Preference - check if value exists
@Preference - check if value exists [message #1737327] Thu, 07 July 2016 06:47 Go to next message
Hey,
I just started using the (efxclipse) @Preference annotation to handle preferences in my application. I am wondering how to figure out if there is a value in the preference store for a specific key.
For example:
@Inject
@Preference(key = "myKey")
double value;
As long as I don't publish any own value for this key, the DI will give a 0.0 value. How can I distinguish this from a real stored 0.0.
My problem is, that I want to publish some initial values but only if there is no value stored already. Any suggestions how I can figure out if there is a value stored for a specific key?
Kai
Re: @Preference - check if value exists [message #1737335 is a reply to message #1737327] Thu, 07 July 2016 07:21 Go to previous messageGo to next message
Maybe you can use the object "Double" instead of the primitive value "double"?
@Inject
Double value;
Re: @Preference - check if value exists [message #1737338 is a reply to message #1737335] Thu, 07 July 2016 07:28 Go to previous messageGo to next message
no, same result. I tried
Double value
double value
Value<Double> value
No difference.
Re: @Preference - check if value exists [message #1737343 is a reply to message #1737327] Thu, 07 July 2016 07:49 Go to previous messageGo to next message
Ok can you file a bug for the Double case - I think we need to modify
the PreferenceValueSupplier for that case.
A work around would be to provide a default value like -1 to find out if
the value is not coming from the preference store.
Tom
On 07.07.16 12:47, Kai Pervoelz wrote:
> Hey,
> For example:
> @Inject
> double value;
> Kai
Re: @Preference - check if value exists [message #1737344 is a reply to message #1737343] Thu, 07 July 2016 08:00 Go to previous messageGo to next message
okay, thanx. The -1 workaround is what I am doing right now but it would be nice to really know if the value exists already in the prefs.
What do you think about adding this information to the Value<T> type, too? As far as I understand I need the Value<T> type to publish the preference to the context, right? So it would be great to only deal with the 'Value' instead of checking the 'Double' first for null and then using the 'Value' for publishing an initial value to the context.
Kai
Re: @Preference - check if value exists [message #1737729 is a reply to message #1737344] Tue, 12 July 2016 06:07 Go to previous message
Not sure I can follow your proposal. Can you rephrase or even provide an
example?
Tom
> Kai
Previous Topic:Eclipse Neon 4.6.0 with E(fx)clipse 2.4.0 not working
Next Topic:How to create and run JUnit tests on FX plugins?
Current Time: Sun Jul 20 18:34:04 EDT 2025
Powered by FUDForum. Page generated in 0.04378 seconds
