Home » Eclipse Projects » OM2M » Running mn-cse in virtual machine.
Running mn-cse in virtual machine. [message #1736633] Thu, 30 June 2016 12:41 Go to next message
Hi all, i'm trying to run the IN-CSE in my computer running Windows and the MN-CSE in a Virtual Machine running Linux OS. I configured the CseBase IP and CseRemote IP according to the IP of the computer and the VM. However, the MN-CSE cannot register in the IN-CSE. I ask if anyone used to do this task for help. Thank you.
Re: Running mn-cse in virtual machine. [message #1736701 is a reply to message #1736633] Fri, 01 July 2016 05:06 Go to previous messageGo to next message
Hello Trung Luu,
The IN must be able to reach the ip:port of the MN and the MN must be able to reach the ip:port of your IN.
Could you check if you can ping (or whatever) each node from the VM and the Windows side?
Guillaume
Re: Running mn-cse in virtual machine. [message #1736781 is a reply to message #1736701] Fri, 01 July 2016 12:31 Go to previous messageGo to next message
I tried to run IN-CSE and MN-CSE in different Virtual Machine and it work. But between real PC and VM, it can ping the IP of the another but the request is still not sent. I don't know what the problem is. Thanks for your help.
Re: Running mn-cse in virtual machine. [message #1736940 is a reply to message #1736781] Mon, 04 July 2016 09:30 Go to previous messageGo to next message
Can you try to run both IN and MN on your real PC to be sure that there is not a hidden issue there?
Guillaume
Re: Running mn-cse in virtual machine. [message #1737214 is a reply to message #1736940] Wed, 06 July 2016 08:55 Go to previous messageGo to next message
Trung, please tell us if Guillaume remark helped you to solve your issue otherwise give us more details.
Re: Running mn-cse in virtual machine. [message #1737222 is a reply to message #1737214] Wed, 06 July 2016 09:08 Go to previous messageGo to next message
I ran both IN and MN in my PC and it works perfectly, it happen so when I run both on Virtual Machine Linux Debian. But when I run 1 of them in my real PC and 1 in Virtual Machine, the request from MN cannot be sent to IN. I'm sorry for late reply.
Best Regards,
Re: Running mn-cse in virtual machine. [message #1737250 is a reply to message #1737222] Wed, 06 July 2016 11:43 Go to previous messageGo to next message
I think you need to open required ports on your machines. E.g. 8080 to reach the IN.
Re: Running mn-cse in virtual machine. [message #1737251 is a reply to message #1737250] Wed, 06 July 2016 11:44 Go to previous messageGo to next message
Dear Mahdi,
it works now, thanks for fast support.
Best Regards,
Trung
Re: Running mn-cse in virtual machine. [message #1737253 is a reply to message #1737251] Wed, 06 July 2016 11:46 Go to previous message
Happy it is working for you.
I will try to help you on the other issue.
Mahdi
[Updated on: Wed, 06 July 2016 11:48] by Moderator
Previous Topic:Create your own Plugin
Next Topic:Trouble with dependencies
Current Time: Sun Jul 20 13:28:36 EDT 2025
Powered by FUDForum. Page generated in 0.05704 seconds
