Home » Eclipse Projects » Sirius » Don't Auto arrange at Container creation(How to prevent that sirius auto arrange the position of a new container)
Don't Auto arrange at Container creation [message #1736243] Mon, 27 June 2016 15:40 Go to next message
Hi all,
everytime I create a new Instance from a Container Creation Tool from the palette, the new container isn't created at the position where I dropped my mouse but somewhere randomly in my diagram.
How to make sure that new containers are rendered at my desired position?
Thank you.
Matt
Re: Don't Auto arrange at Container creation [message #1736254 is a reply to message #1736243] Mon, 27 June 2016 17:05 Go to previous messageGo to next message
Le 27/06/2016 à 21:40, Matt Se a écrit :
> Hi all,
Is the "snap to grid" enabled [1] ? This can explain this "random" behavior.
The container should be rendered at the desired position (except with
"snap" features).
> Thank you.
> Regards,
> Matt
[1]
https://www.eclipse.org/sirius/doc/user/diagrams/Diagrams.html#Snaptogrid
Laurent Redor - Obeo
Re: Don't Auto arrange at Container creation [message #1736799 is a reply to message #1736254] Fri, 01 July 2016 16:14 Go to previous messageGo to next message
Thanks for your help.
Diabling the "snap to grid" did not work.
But I found the issue.
I used Java Services to initialize my new EObject with some other EObject contents.
Turns out I have to perform these init Operation first, bevor adding the new EObject to it's parent to prevent this behavior.
Re: Don't Auto arrange at Container creation [message #1736881 is a reply to message #1736799] Mon, 04 July 2016 03:50 Go to previous message
Thank you for clarifying that the problem was solved
> But I found the issue. I used Java Services to initialize my new EObject
Previous Topic:Autoresize compartment
Next Topic:How to get all Editparts from a Sirius Diagram
Current Time: Sat Jul 19 09:34:21 EDT 2025
Powered by FUDForum. Page generated in 0.03429 seconds
